Sponsored by: Auxito
2000 F150 ABS Problem.
Old Jun 27, 2006 | 10:13 PM
tarzanjane's Avatar
tarzanjane
I really would not mind running it with the light on but I need to get rid of the fault to pass inspection.
I changed the rear speed sensor first, no change. Then I paid to get the codes read as was suggested by others.
I got back a C1155 Left front sensor reading off speed. C1096 Pump Motor and a Circuit failure C1095 ABS Pump Motor Failure.
I was told there was a pump which is news to me and there is possibly a relay that has failed. I could not find anywhere in the owners manual a relay for the ABS. I did find a fuse which is fine.
Any tech's out there that can help?
<!-- / message --><!-- no sigs except when logged in -->
Old Jun 28, 2006 | 06:58 AM
projectSHO89's Avatar
projectSHO89
If your first interest is in passing inspection, remove the ABS light from the cluster, then take it somewhere else for inspection. They'll never notice it being gone and won't fail the inspection.
Otherwise, look up your state's official safety inspection criteria and see if a fault in the ABS system can cause an inspection failure. Since it's an additional system and your primary braking system is not affected, it may not be a failable condition. I'd expect each state that has an inspection program will have similar rules, but there will be differences. For example, in Missouri's inspection procedures, the ABS system is specifically listed as not to be tested (11 CSR 50-2.160 (1(D)))
As for repairing the actual faults, you have a detected fault in the LF sensor or ring gear AND an electrical fault with the pump motor circuit. The service manual has the step-by-step procedures for diagnosing these concerns which may be beyond the resources of most vehicle owners.
Steve
Old Jun 28, 2006 | 09:33 AM
tarzanjane's Avatar
tarzanjane
Service Manual
Can you direct me to a link for a 2000 F150 service manual? It would be money well spent. Is there a PDF copy I can down load?
Thanks for your help.
Pocket
Jul 7, 2023 02:50 PM
00SD73
Escape & Escape Hybrid
Apr 26, 2016 03:55 PM
jaoneill
Jul 19, 2013 04:14 PM
SuperMike
Jan 23, 2012 04:03 PM
uncleAl
Sep 8, 2007 05:47 PM
