ABS light on need help ASAP
Old Sep 7, 2007 | 06:32 PM
uncleAl's Avatar
uncleAl
Lightbulb ABS light on need help ASAP
99 explorer 4x4 / I bounced over the unfinished curbs in my new subdivision and
the ABS light came on. the wire to the rear axle is intact and so are the front.
My Auto Enginuity diagnostic program spit out these codes.
C1102 ABS Acceleration switch circuit failure
C1230 speed wheel sensor rear center input circuit failure
P1804 4-wheel drive high indicator circuit failure
B1347 heated backlite relay circuit failure
any ideas
Old Sep 7, 2007 | 08:44 PM
Wilber15's Avatar
Wilber15
It's the rear WSS. remove the wiring harness to the rear diff sensor. take and ohm meter and ohm across the 2 sensor connectors. if you get O.L.(Open Line), it's a bad sensor. replace it. see it all the time...
Old Sep 8, 2007 | 05:47 PM
uncleAl's Avatar
uncleAl
Thumbs up
Wilber15 thanks for the info on testing the sensor, that's what the problem was.
I owe you a beer.
ReBilld
Crossovers
Mar 30, 2018 07:08 PM
Rusty Axlerod
Nov 5, 2015 04:29 PM
HKusp
Oct 21, 2015 10:35 AM
PSD666
2009 - 2014 F150
Jul 12, 2015 09:18 PM
Delvac1
Oct 9, 2008 10:42 PM
