Sponsored by: Auxito
OK Where is it.......
Old Jun 26, 2006 | 10:51 PM
Cessnadriver's Avatar
Cessnadriver
1997 F-150 4X4 with 4.6 "W" engine. Auto w/ Air
Where is the Blower motor resistor.
Under the dash or under the hood.
If it's under the hood, is it behind the battery somewhere?
Inquiring mind wants to know.
I've heard both locations described on forums....
Thanks
Old Jun 27, 2006 | 07:30 AM
Board627's Avatar
Board627
under the hood I believe by the battery like you stated
Old Jun 27, 2006 | 08:12 AM
projectSHO89's Avatar
projectSHO89
Blower motor resistor location - 1997
Geez....
The A/C blower motor resistor is installed in the A/C evaporator case next to the blower motor. It is kept in the plenum airstream to provide cooling for the heat disippated by the resistive elements.
On the 97, it is located directly behind the glovebox next to the blower motor. You just about have to stand on your head to see it or its mounting screws.
Steve
Old Jun 27, 2006 | 10:13 PM
Cessnadriver
Originally Posted by projectSHO89
Geez....
Steve
Thanks, Steve
Under the dash.....
5 minutes, a mirror, flashlight and 8mm socket.
Part $15.
Problem solved
Fan was only working on High.
Old Aug 30, 2006 | 11:24 PM
frankl1955's Avatar
frankl1955
Thanks Steve, I had same problem. I have a 97 explorer that I bought used and so far its been (Fix Or Repair Daily)
Frank
1912barry
Oil & Lubrication
36
Dec 14, 2016 06:26 PM
Sharpshooter77
Feb 18, 2009 10:31 AM
El Gato
1997 - 2003 F150
19
Jan 3, 2008 07:24 PM
86f350diesel4x4
Feb 18, 2003 08:27 AM
PostalDave
1983 - 2012 Ranger & B-Series
Oct 14, 2002 03:06 PM
