hood seal
Old Feb 16, 2003 | 09:58 PM
86f350diesel4x4's Avatar
86f350diesel4x4
hood seal
where can i find the weather seal that goes under the hood on the cab end of the hood. i keep gettin water in and it sits on the intake cover. its an 86 f350
Old Feb 17, 2003 | 10:11 AM
Towmanjbo's Avatar
Towmanjbo
hood seal
deleted
Old Feb 17, 2003 | 12:54 PM
rmccann4's Avatar
rmccann4
hood seal
Hi,
Bought mine from Jeffs Bronco Graveyard. It fit on truck perfect and stopped my leak. I see they stock for Ford trucks too: '87-'91 Hood Cowl Rubber $30.00 + shipping. Look under '80-'96 Fullsize Parts
Hope this helps!
Ron
Old Feb 18, 2003 | 08:08 AM
steve83's Avatar
steve83
hood seal
It's easy to find good ones in a junkyard. You can use '80-97.
Old Feb 18, 2003 | 08:27 AM
HotWhlz85's Avatar
HotWhlz85
hood seal
Hey 86F350 and welcome to FTE.
When I swapped out engines I had the same problem. I looked at several places for new and didn't like the prices I found. So I made one out of garage door weatherstripping. It's about 1.25 inches wide with a slight bend in it. Comes in a 16' roll and goes along the bottom of a garage door and I got it at Lowe's.
I measured and cut how much I needed, applied a bead of silicon sealer to the firewall, and then used the existing screws from the old hood seal to mount it. Due to the soft nature of the weatherstrip I added upholstery washers to the screws. A year later and it still looks brand new and the best thing is no more water on my intake.
cowdog86
Aug 31, 2016 12:01 AM
HarleyLover
Jan 8, 2016 11:49 PM
rebar13
13
Oct 10, 2014 11:03 AM
midsouth
Aug 15, 2014 06:28 PM
Kenworth
19
Apr 21, 2010 01:32 PM
