Engine Fire...
Old Jun 24, 2006 | 12:24 AM
67f100's Avatar
67f100
Engine Fire...
[IMG][/IMG] [IMG][/IMG]
A couple of weeks ago my brother in law experianced an electrical fire that started somewhere near the battery. It's (I think) a 71. with a 390. The fire burned and smoked for about 15 minutes. It was put out by the fire dept. My question is, is the motor it self any good? I know I will have to replace a few things (like the ignition system and carb) But could the fire itself damaged the motor at all? He's giving it to me so I would like to get some info as to wether it is salvageable. I have more pics in my gallery.
Old Jun 24, 2006 | 12:28 AM
fordraceboy's Avatar
fordraceboy
should be okay... pull the plugs before you turn it over cause its a guaranteed certainty that it's full of water.. drain the oil also... should be alright.. i've caught my old fords on fire before and thats all I ever did... well, that and rewire it all... LOL
Old Jun 24, 2006 | 12:43 PM
Hypoid's Avatar
Hypoid
My brother mentioned something about the dry powder type extinguishers leaving abrasive powder all over the place. Just something to keep in mind.
Sucks about the fire but hey, it's yours now. LOL
Old Jun 24, 2006 | 01:51 PM
Bear 45/70's Avatar
Bear 45/70
If the fire department put it out, they used either water or foam. They rarely, if ever use dry chem except in a house with a stove or oven fire. Our engine only has on dru chem extinguisher onboard.
Old Jun 24, 2006 | 03:23 PM
67f100's Avatar
67f100
Yea, Bear, I believe it was foam.
Old Jun 24, 2006 | 03:44 PM
fordraceboy
well hey, if you don't want the hassle or the trouble and it's a 390, pm me and let me know, i live about 2 hrs from bend in the valley..
Old Jun 24, 2006 | 03:54 PM
Bear 45/70's Avatar
Bear 45/70
Call the fire boys and ask them what to use to clean it off. The last foam I was involved with had a solvent of it own. I have been fire fighting for over 10 years now but I do know they have a new type foam (the wife is still a fire commissioner and I remember talking about the new stuff being cheaper, working better and easier to clean up. So the new stuff may well just use water.
Old Jun 26, 2006 | 08:44 PM
67f100's Avatar
67f100
Another quick question. Will the distributor from the 352 fit and work on the 390?
Old Jun 26, 2006 | 09:16 PM
Bear 45/70's Avatar
Bear 45/70
All FE parts except some heads, pistons, rods and cranks all interchange. So yes the dist. will work.
