Bronco II Ford Bronco II
Rim Backspacing
Old Jun 23, 2006 | 11:25 AM
bronco2454's Avatar
bronco2454
Rim Backspacing
I am wondering what should the backspacing on the rims be if you are looking to replace the factory rims and there are no lift kits or anything of that nature. I am looking into a set of Cragar Nomad II's anyone know if they will fit.
Old Jun 23, 2006 | 12:24 PM
kernel-panic's Avatar
kernel-panic
I believe that factory backspacing is 4 1/2".
Old Jun 23, 2006 | 03:51 PM
rebocardo's Avatar
rebocardo
The back spacing for the rim is 3" on the stock 15x6 rim. Rims off pretty much any Ford truck is a 50/50 split except on DRW.
Old Jun 23, 2006 | 07:16 PM
kernel-panic
Okay. I just went out and measured from the mounting flange to the inner lip on the rim on my stock steel spare tire rim, and it's about 4-4 1/2", and my best guess on the stock aluminum wheels are the same. However, it's probably about 1 1/2" from the outer lips to where the tire bead seats on the rim, so.... if that is the backspacing, then rebocardo is correct
Old Jun 26, 2006 | 11:11 PM
bronco2454's Avatar
bronco2454
Would a 15x6 rim fit with a Rear Spacing of 3-3/4''
ThoobHertz
2009 - 2014 F150
Jun 17, 2016 02:53 PM
gunnibronco
May 26, 2015 10:02 PM
warrens73
Oct 29, 2014 08:27 PM
cowboyup1988
Mar 5, 2010 08:38 AM
