4.0L Engine Upgrades
Old Jun 22, 2006 | 11:26 PM
hosdv19's Avatar
hosdv19
I just bought a '04 2wd with the 4.0L v6 Auto and am looking to doing some engine upgrades. I'm planning an exhaust system for it shortly, but what else can I do without really getting into the engine internally? I'm looking at the power programmers on the market, but will this give me all the power possible by itself or do i need to some other upgrades to help it out? Any help would be great!
Old Jun 23, 2006 | 04:41 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Engine swap (v8).....more cubic inches is the fastest and most effective way to produce a honest, meaningful, and worthy of discussion result. If you like the incrementally small and slow route, you're gonna get ideas shortly.
**We just had a thread along these lines a few days ago and it's very interesting that this subject came up again so soon. Most interesting. Hmmmmmmmm. I can only wonder how many hours this thread will last. On the flip side, this forum has had no *real* and attentive mod review and it hasn't since April of this year (2006). In fact, some long timers here will readily admit our once tech savy and knowledge wealthy forum had gone down the gutter . None the less, you will def be getting feedback and ideas that are worth considering and in some cases worth maybe even pursuing.
Old Jun 23, 2006 | 06:18 AM
pawpaw's Avatar
pawpaw
Welcome to FTE hosdv19
Are you looking to make HP, to go fast, or Torque to get off the line, or GRUNT for hauling or towing????
As Bill pointed out, this has recently been posted about in some detail.
You might look through the postings in the following threads, or try a site search for 4.0L upgrades. https://www.ford-trucks.com/forums/s...d.php?t=500121 & https://www.ford-trucks.com/forums/s...23&pge=1&pp=15
Old Jun 23, 2006 | 06:28 AM
wendell borror's Avatar
wendell borror
Here We Go Sports Fans !!!!!!!!
Old Jun 23, 2006 | 01:15 PM
hosdv19's Avatar
hosdv19
i see....
ya i saw the thread on the 3.0L upgrades and wasn't sure if they would be the same. sorry about the repeat and will look up the other threads on the matter.
Old Jun 23, 2006 | 01:26 PM
wendell borror
It's not the same, the 3.0 is weak, the 4.0 rocks, check my pm, it will give you some good idea's. The guys live for these threads, how boring thier lifes would be without performance topics. I built a 4.0, so what do you want to know?
Old Jun 23, 2006 | 01:29 PM
hosdv19's Avatar
hosdv19
I just looking to bolt some things to her, I willing to put up some money but i'm not gonna to crazy and tear the cam out or pistons etc. Just looking for some realiable everyday power that'll make this truck really fun. Torque is more what i'm looking for, not real interested in during a 110 in my truck.
Old Jun 23, 2006 | 01:52 PM
wendell borror
For torque, get an electric fan, udp, and a programer, also headers are good.
Old Jun 23, 2006 | 02:01 PM
hosdv19's Avatar
hosdv19
excellent, but call me a dummy, i'm not familiar with udp (new to these forum shorthand). I thought about headers but my buddy said they get to hot and burn up starters, then again he had this problem with this 65 'stang.
Old Jun 23, 2006 | 03:32 PM
CowboyBilly9Mile
What rear axle ratio do you have now?
Old Jun 23, 2006 | 06:50 PM
hosdv19's Avatar
hosdv19
it's stock, can't imagine thats its 4.10 , i would guess probably 3.56 or in that neighborhood...
Old Jun 23, 2006 | 07:49 PM
bigdavesohc's Avatar
bigdavesohc
Look in your door jamb for the Axle code. Post it and we will be able to tell you what the gear ratio is.
Also, look into an after cat exhaust, and a K&N Series 77.
Old Jun 24, 2006 | 06:25 AM
wendell borror
Jba headers can be had with ceramic, and titanium coating to cut down on heat, I haven't had a problem, Yeah, gears are a great power booster, thanks Billy, I wasn't even thinking about gears for once ha ha. Also, there's a great programer that alot of us use, thats just awesome, tunned just for rangers, I can't give the name, or the mods won't let my post print, I'll put it in your private message box. When going with a catback, don't go with to big of pipes, go no bigger than 2.5", and single in, and single out, or you can loose lowend torque. The bigger pipes work better in the higher rpm ranges. Most ranger cats come in the 2.5", not a problem. UDP, means under drive pully, under dog sells them.
Old Jun 24, 2006 | 06:39 AM
wendell borror
"O YEAH", a good electric fan is perma-cool, they use metal blades, where as black magic uses plastic, and I have broken the plastic ones in the mud, so I went with perma-cool, I haven;t had a problem since. The udp, and e-fan will give you more usable torque to the wheels, instead of being parastic drag on the engine.
Old Jun 24, 2006 | 06:52 AM
Bob Ayers's Avatar
Bob Ayers
Actually the gain from an e-fan isn't that much due to these points:
1) If fan clutch is working properly, fan load is not continuous
2) Power for E-fan is coming from alternator, which puts a load on the
engine.
