Appreciate the input, so far this is what I have tried - replaced with brand new starter, fuse #113 has 12 volts when key in run position, replaced lower ignition switch under column, can not find a relay anywhere on firewall or fender. One note, radio only works in auxillary position. No fuses are blown. Thank you again if anyone has an idea - still trying it all.........
I am going to need to wait until; I get ho9me, I apologize, I meant to bring some info with me today, left it on the counter. I will respond again after 4:00 today, sorry about that..
