bad CPS
Old Jun 25, 2006 | 12:04 PM
Hiflyer746's Avatar
Hiflyer746
ya
Well I usually agree with the simple logic. The only thing I've touched is the CPS and the wires, so since both CPS's are not working, it must be the wires. But wierder things have happened, and it seems that I really don't have fuel pressure, so either way, I need to figure that one out too. Thanks plowhand, I'll let you guys know.
Tim
Old Jun 25, 2006 | 12:59 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You will only have fuel pressure while the engine is running or cranking (actually turning over). The fuel pump is driven off of a cam lobe. Make sure that the fuel filter housing has fuel in it. But I would still take a real long look at the CPS wiring first.
Old Jun 25, 2006 | 01:53 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I second plowhand- check for fuel in the filter housing. If it's dry or very low it's either the mechanical fuel pump or possibly even your fuel tank selector valve if you have dual tanks. I had mine stick halfway one time but after cycling the switch a few times it worked fine.
As for the cps it is unlikely (but still possible) that you had two bad ones in a row. The electrical connector for the cps would be a more likely suspect but if the tach seems to be working, I would address the lack of fuel pressure first. There's also the screen in the filter housing that should be looked at. Have you ever cleaned it?
If you do open the filter housing check to see if the fuel looks dark colored, bad injector o-rings can cause thi.
carguy3j
92
Jun 9, 2021 06:16 AM
bubba_3711
Mar 20, 2016 02:17 PM
duggyb
15
Mar 8, 2016 07:45 AM
hdgapeach
33
Nov 24, 2015 12:59 PM
Hussler
Sep 19, 2015 03:54 PM
