7th cps in a row
Old Mar 19, 2016 | 11:54 AM
bubba_3711's Avatar
bubba_3711
7th cps in a row
I just bought my 7th cps sensor in a row. Got the grey one from ford this time. Still didn't fix it.
Maybe it's not a cps?
My pickup shuts off for a split second while driving like a bad cps. It does this like 3-4 times in a mile. But if you set the cruse control it doesn't do it.
Old Mar 19, 2016 | 12:05 PM
fordpride's Avatar
fordpride
You have a bad tps
Old Mar 19, 2016 | 12:36 PM
bubba_3711's Avatar
bubba_3711
Do they sell the tips sensor at ford?
Old Mar 19, 2016 | 03:19 PM
fordpride's Avatar
fordpride
For only sells the whole pedal assembly. The only aftermarket part is dorman part #699-200
Old Mar 19, 2016 | 07:32 PM
z31freakify's Avatar
z31freakify
APS (accelerator position sensor) does the engine shut off or do you loose throttle when it does this?
Old Mar 19, 2016 | 08:39 PM
Seanosu's Avatar
Seanosu
It's an idle validation switch. When the throttle is in the idle position the switch is closed and it tells the computer to "idle only".
Old Mar 19, 2016 | 08:52 PM
fordpride's Avatar
fordpride
False. You can unbolt the switch and let it lay on the floor the click it one time and drive the truck all day till you shut it off. Then you'll have to click it again.
I fought this problem for months.
If it doesn't do it when using CC it's the TPS
Old Mar 19, 2016 | 09:16 PM
Seanosu's Avatar
Seanosu
Ford pride if you read my original post, I stated if the switch is "closed" then the truck will idle only no mater what the throttle position, not if you click it once.
Old Mar 20, 2016 | 06:07 AM
bubba_3711's Avatar
bubba_3711
I just lose throttle for half a second. Seams to do it more when the pickup hasn't warmed up all the way. It also never does it at 3/4 throttle or full throttle.
Old Mar 20, 2016 | 11:36 AM
ReBilld's Avatar
ReBilld
I'm with Mike on this. Its sounds like the TPS to me also.
Old Mar 20, 2016 | 12:15 PM
madpogue's Avatar
madpogue
The idle switch is OPEN at idle, and CLOSES when you move the pedal. An interruption in power to the idle switch, or the switch itself opening momentarily, would simulate the driver briefly letting off the pedal and pressing it again. So it could be either one. To absolutely narrow it down, you'd have to get a live data recorder on it, and record APS voltage (or %) and IVS state, and set it to a pretty fast refresh/sample rate (faster than 1/second), and record the stream over the time that this happens.
Old Mar 20, 2016 | 12:51 PM
fordpride's Avatar
fordpride
But if cruise control is set then the TPS is out of the equation. If it was the ivs then it would do it whit the CC set.
Old Mar 20, 2016 | 02:17 PM
madpogue's Avatar
madpogue
When cruise control is set, BOTH are out of the equation. When you set the cruise and take your foot off the pedal, the IVS is open the whole time. Set the cruise and play with the pedal; it won't affect the speed (unless you press the pedal to go above the set speed).
dn29626
Aug 27, 2012 10:05 PM
Whitey Ford
15
Sep 15, 2010 09:31 AM
charlie92/7.3l
Feb 9, 2009 09:26 PM
redneckcad
General Automotive Discussion
19
Feb 5, 2008 08:18 PM
