General Automotive Discussion
General Front Suspension Question...
Old Jun 20, 2006 | 06:12 PM
Beast12's Avatar
Beast12
Question General Front Suspension Question...
Well, we know how all new front-end suspensions are "sealed for life". So, they don't have grease points. With that said I have ALWAYS greased a vehicle EVERY oil change (3 months). My motto: Grease is cheap, labour and parts are not.
Now, to my question. Would it be better to "puncture" the boot on a ball joint and squeeze in some grease or just leave it alone until it fails then replace it with a greasable joint? Also, same question for tie-rod ends.
Thanks.
-Matt
P.S. This question is for, of course, my Focus.
Old Jun 20, 2006 | 09:41 PM
vman's Avatar
vman
You could do that and get some grease in there,along with dirt,water,salt,etc.
Old Jun 20, 2006 | 09:51 PM
Fordzlla's Avatar
Fordzlla
leave it alone!
There's no reason to expect that the suspension parts won't last the life of the car under normal use and conditions.
Old Jun 21, 2006 | 12:54 AM
rywegh's Avatar
rywegh
Sorry Fordzilla but that I know is false. Every Ford that I have had with "sealed for life part" went bad within 60000 miles or soon there after. I do know my dads Ranger lasted a little longer. I also know that the replacement moog parts come with zerk fittings.
P.S. Matt why don't you just give those mice some osteobiflex so they quit squeaking. At least more cheese.
Old Jun 21, 2006 | 05:23 AM
Beast12's Avatar
Beast12
Well, they aren't squeaking yet but oh well, maybe I will try the cheese.
-Matt
Old Jun 21, 2006 | 07:57 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I wouldn't touch it - more so in your winter climate with salt on the roads
Old Jun 21, 2006 | 10:26 AM
jimandmandy's Avatar
jimandmandy
If the boot is good, dont break the seal. My F-150 ball joints were still perfect when I sold it at 150,000 miles. Once the boot is damaged, then regular greasing is a must. Some sealed ones have a pastic plug over the threaded hole and all you have to do is add a fitting. The Chevy had fittings on everything and I did grease them annually. I sold it at 100,000 so I dont have an exact comparison of durability.
Jim
Old Jun 21, 2006 | 12:14 PM
Beast12's Avatar
Beast12
I wish. I will double check but I don't think they are there. Ticks me off that it comes down to this because humans are too lazy to maintain their vehicles. I am glad I am not one, a human that is.
-Matt
Old Jun 21, 2006 | 02:03 PM
Fordzlla's Avatar
Fordzlla
D
The reason they fail is because the seals start to leak(or someone has poked them with a grease neeedle or pressure washer) and water or dirt gets in .
I've seen minivans go 200k with no problems on the front end parts.
My '70 4x4 with grease fittings everywhere needed a total front end rebuild at 70,000 miles.
aphotic26
Sep 11, 2021 05:37 PM
sammie0126
Nov 29, 2012 03:50 PM
Duke78
Nov 4, 2008 05:21 AM
MikeFlorida
May 13, 2007 06:52 PM
jcv44wf
Sep 23, 2002 11:31 PM
