Oil Leaks
Old Jun 20, 2006 | 11:48 AM
Billh2's Avatar
Billh2
Oil Leaks
Like any good Ford, my 88 F-150 leaks a little oil. I took it in and the guy I usually have work on my vehicles told me the oil was coming from the valve covers and the trans oil pan. He quoted me $500.00 to fix everything. Seemed a little high, but he says the upper intake manifold has to be removed to get to the right side valve cover. How big a job is that? I guess I need to buy a manual.
Thanks<O
Bill<O
Old Jun 20, 2006 | 02:10 PM
Jefe's Avatar
Jefe
I think the price sounds about right. Assuming you have an 8cyl with EFI, that valve cover on the right looks like a real pain because of all the stuff that has to be removed - I've never attempted it myself though. Also, from what I've been reading around here, the oil pan can be a pain to get to. Oh, wait, you said trans oil pan - I think that's a bit easier to do.
And there's my $.02 - but take what I say with a grain of salt, cuz I'm still a noob to Ford trucks.
Old Jun 20, 2006 | 02:37 PM
shooter05's Avatar
shooter05
The top does have to come off to fix the valve cover gasket. The price doesn't seem too bad. The ford v8 is famous for leaks around the valve covers. I have propped the cover open as far as possible without removing the top end. I use blue goo and forego adding another gasket. If you don't want to spend the bucks just blue goo it as best as can be. It will help.
Old Jul 3, 2006 | 07:46 PM
jcjk420's Avatar
jcjk420
maybe someone has some input on my oil leak, I just bought a 94 f-150 4x4 with a 5.0
v-8.I got some good advice on a tranny problem that saved me a bunch of cash and hoping I can get the same on this issue, I seem to have oil leaking arround my starter I
don't believe it can be a rear mail seal just wondering if this particular make or model is
noted for this type of oil leak,any input would help!
Old Jul 3, 2006 | 09:11 PM
924x2150's Avatar
924x2150
BillH2...what engine is between the front wheels?
WARNING!!
Many unscrupulous shops will repair your leaks for you, the engine stays clean for about 2000 miles then everything opens up again. Be careful! What you must remember is that many shops will do the gasket repairs because it sounds alot better ( or cheaper) than a minor engine rebuild ( new rings, head etc.) These unscrupulous or maybe ignorant low-lives will take your 500 bucks, and then try and get you for another 1500 bucks later when the leak starts again. ( i know this for a fact..been there done that, )Many times the engine starts leaking out the valve cover, lifter cover and pan, because the rings and cylinder walls are shot and exhaust gases are getting past the combustion chamber and entering the oil crankcase.The gaskets can't take much pressure they aren't designed to.
Any engine work should only be performed after a good tech determines that the combustion chamber pressure is in spec, there is no combustion blow-by in the crankcase, and the engine is showing good vacuum readings, otherwise you'll waste your money.
Old Jul 3, 2006 | 09:43 PM
Billh2's Avatar
Billh2
WARNING!!
Yea, I have lots of horror stories along those lines. Up until 1990, I worked in the automotive industry. I have known the guy who quoted me on my truck for a LOT of years. The engine is a 5.8, When I got it, first thing I did was check gas mileage. It was getting 9. A plug change bumped that to 13. I wonder if a set of headers would improve on that.
Later
Bill
Old Jul 3, 2006 | 09:44 PM
mississauga's Avatar
mississauga
I have replaced valve cover gaskets on my 88 f150 a couple of times. There is a bunch of things to remove to get to them. As stated by other posts upper intake has to come off to do the passenger side.Not a real tough job but a little hard on the back from leaning over the engine for a few hours.Upper intake has a allen head style bolt in the middle which can frustrate you if you dont notice it right away.Be careful as not to drop anything in the lower intake during disassembly/assembly. Having a manual wouldnt hurt.
Old Jul 3, 2006 | 09:47 PM
Conanski's Avatar
Conanski
This can be a DIY job. Do yourselves a favor an go to the FORD parts department and order the 1 piece metal core rubber coated valve cover gaskets. These are reusable, will take more torque than the cork gaskets, and generally don't leak. FMS part number M-6584-A50. There is also a 1 piece oil pan gasket, but you'll have to pull the motor to change that. There are 6 bolts holding the upper intake on, plus various hoses and cables... it's not as bad as it looks. The tranny oil pan is dumb simple to remove, but it'll make a hugh mess with 6 liters or so tranny fluid trying to escape from all sides. I put a drain plug in mine years ago.. now fluid changes are simple.
Old Jul 3, 2006 | 09:51 PM
mississauga
Conanski makes a good point. Stay away from the cork gaskets.
Old Jul 4, 2006 | 01:19 AM
Billh2's Avatar
Billh2
When I took it in, I asked the tech if he had checked to see if the VC bolts were all tight. He said that he wouldn't do that because of the chance of splitting an oil soaked cork gasket and making the leak worse. When I changed plugs, I found a piece of old valve cover gasket laying on the engine. Like someone had changed gaskets before. Figuring I had nothing to lose, I tightened the valve cover bolts. To my surprise, a number of them took about 3/4 turn then seemed to bottom out. So far, it appears the leak has stopped. Keeping my fingers crossed.
Thanks
Bill
Karl Aube
Sep 16, 2008 10:13 AM
kdjohnson007
2004 - 2008 F150
Jun 30, 2007 03:23 PM
DOHC330MustangGT
62
May 29, 2007 10:53 PM
jd111404
Apr 21, 2007 12:25 PM
pforr
Feb 23, 2007 01:38 AM
