Hey! I was drilling out a header stud, and went to deep and got into the water jacket. I was gonna pematex the threads to seal it, but didnt know if this was strong enough to hold the pressure. Any ideas? Should i use threadlock instead? THanks for your help.
Wrong forum or not.
My recommendation would be to use teflon pipe thread sealer. Not teflon tape...although that might work. But teflon pipe sealer works great for that purpose. I've had the same problem, and teflon sealer has work fine. I wouldn't recommend an RTV sealer, because a lot of those type of sealers of for oil only, and not sealing coolant/water.
Good luck
Little help please, i wanna put it together tommorow!
sorry i did not see your post sooner. 4 days at englishtown raceway park for the K&N nationals raceing.
check out this web site they make blind plug thread repairs for problems such as this. check thoughout the site as they make a lot of top notch items to save motors from this and other problems
http://fulltorque.com click on site map and follow the links. they will lead you to the blind thread inserts to repair your problem. many guys may want to book mark the site for future use because if read you will find they even make plugs to fix just about anything cast iron or alloy. and have saved me countless times when i did the same problem to my self
A friend of mine did that exact thing on his RV with a 460 in it. He found a good weldor and they put a stud in and welded around it with a mig welder. Then they ground it flat-end of problem. They will tell you you cant weld cast iron but you can if the guy's good.
