AOD Oil Pan Drain Plug
Old Jun 14, 2006 | 05:13 PM
51dueller's Avatar
51dueller
I just noticed today that the drain pan plug on my transmission is ripped. When I crawled under the truck, I had noticed the ground was dark and the rubber plug was wet. I gave the plug a little tug and it ripped in half. There is a little piece of it still in the pan. Should I drop the pan to take the little piece out or just put a new plug in? I changed the tranny filter and gasket last year
Old Jun 14, 2006 | 07:59 PM
stuart1's Avatar
stuart1
I have never seen an AOD with a rubber plug as you mention.
Or any plug for that matter, especially on a factory transmission.
Usually aftermarket plugs are metal.
Old Jun 15, 2006 | 04:25 PM
51dueller's Avatar
51dueller
I wonder if a previous owner made his own drain plug. It's in the back corner on the drivers side. I'll try to get a picture.
SoCalAngler
May 15, 2014 04:22 PM
SoCalAngler
May 13, 2014 06:33 PM
WINGNUT-
13
Aug 14, 2011 07:59 PM
thbowen
Apr 24, 2009 06:02 PM
