check engine light code 172 174
Old Jun 14, 2006 | 11:32 AM
93truck's Avatar
93truck
Question check engine light code 172 174
can anybody tell me what these codes mean and what is wrong. my truck is a 93 f-250 4x4 5.8l auto
Old Jun 14, 2006 | 12:28 PM
ncranchero's Avatar
ncranchero
https://www.ford-trucks.com/article/..._Metering.html
Old Jun 14, 2006 | 12:29 PM
FlairSide's Avatar
FlairSide
looks like you are running rich and lean at the same time.
Old Jun 14, 2006 | 07:30 PM
lv2race's Avatar
lv2race
Those are codes for OBD-II, which I believe handles 1996 on. 93truck, you should have EEC-IV and Code 172 is O2 sensor voltage signal lean on Bank 1. Are you sure you got Code 174? I don't see that code in my manuals. Maybe code 74, which is only a self test error code.
Old Jun 15, 2006 | 10:25 AM
93truck's Avatar
93truck
fat finger error
the codes are 172 173 which i was told its running lean and rich, which i could believe because sometimes its smells rich and black smoke. light only comes on after a few miles and sometimes it will go off and stay off for some time. also at idle it surges up and down
Old Jun 15, 2006 | 10:35 AM
fordpaul's Avatar
fordpaul
May be just a bad 02 sensor. Take a look at the outer housing on the 02 sensor & see if it is rusted/cracked on the outer housing. The 5.8l's we're known for that.
Old Jun 15, 2006 | 01:32 PM
lv2race's Avatar
lv2race
Disconnect the negative battery cable, replace the O2 sensor, re-connect the cable and you should be good to go.
Old Jun 15, 2006 | 09:53 PM
93truck's Avatar
93truck
hey, thanks for the info, replaced o2 sensor runs great
camping truck 93
Sep 1, 2020 05:55 AM
bryanrandall
Jan 19, 2017 07:00 AM
andyj93f150
Sep 10, 2015 07:37 AM
GhostF250
Aug 27, 2010 04:37 PM
MemOrex
80
May 29, 2008 09:04 PM
