Predator Stage II Fuel/Boost
Old Jun 14, 2006 | 06:35 AM
Excursionator's Avatar
Excursionator
Throughout these forums I've read postings about the Predator "plug and play" programmer product(s) and - the general trend seems to be less that positive.
However, I have found nothing on the Stage II item that plugs between the ICP sensor and then links into the MAP sensor wire.
I have part #3013 installed on my 04 6.0 PSD as well as an Edge Platinum programmer - I DO NOT RUN BOTH AT SAME TIME - and the Predator seems to have a bit more low RPM power and I know I get better milage with the Predator than I do with the Edge set to "Driving"
Having said all that, if I am running the risk of problems running the Predator I will switch back to the Edge.
Thoughts?
Thx, JC
Old Jun 14, 2006 | 06:07 PM
bgrover's Avatar
bgrover
All I know is I run a predator in my F350 on the highest setting and have not had a problem.
Old Jun 15, 2006 | 05:59 AM
Excursionator
thanks for your time
Old Jun 17, 2006 | 10:35 PM
LAWNMOWER MAN's Avatar
LAWNMOWER MAN
I Ran It Wi My Edge Up To Setting 3 But Didnt Like Edge's Trany Programinstalled Sct W/ Custom Tunes Does Anyone Know If I Can Run It With My Tow Tunes ?
Old Oct 21, 2006 | 10:04 AM
southbound35west's Avatar
southbound35west
diablo sport
do u run larger exhaust on you truck, what kind of mileage do u get? i have ran the 100 hp tune 1 time and it gave this 2006 ps some unbelivable power, but i was told i better run larger exhaust to keep the egt's down, and a egt gauge to watch the temps, but i have been running a 65 custom tune from diablo for 1 year have had no problems and it gives alot of power
Old Oct 21, 2006 | 01:20 PM
one4speed's Avatar
one4speed
I don't think he is refering to the Diablo Predator. Isn't this the module that plugs in under the hood?
I have heard good things about fuel mileage with these. What kind of mileage gains are you talking about? What kind of performance gains are you seeing? Does it smoke heavy under load? How are the EGT's? The 6.0 needs a little help with the bottom end torque. You say it helps and that has my interest. Just keep an eye on things. The 6.0 doesn't like excessive cylinder pressures. I would call the manufacture of the programmer or box. Ask them about towing and what to watch for on cylinder pressures (driving conditions to watch for). Cylinder pressures are a much bigger concern with the 6.0 than egt's. Your factory water temp is a pretty good indicator of cylinder pressure. If you see the temp gauge climbing use caution. The turbo on the 6.0 will open up and do a good job of dumping egt heat. Please give me a little feedback on the performance and egt's on this box. I know someone that is interested in something like this. I believe this is the product he has been looking at.
Just my .02 Someone with more knowledge should be able to expand on this
one4
mdelfunt
Mar 30, 2015 03:00 PM
bigfoot7180
Nov 26, 2012 12:53 PM
s2gots
All Things Towing
Sep 17, 2007 12:28 AM
riceman
Oct 27, 2005 01:32 PM
Sidewaze
Nov 20, 2004 11:53 AM
