I need help I'm leaking from the front wheel on the passenger side. It's green looking mixed with water not thick but dont smell like antifreeze. I was running the AC all day yesterday and went to the dealer early in the morning for an inspection it pass but now notice this leak. All gauges are okay and its not running hot. Cant tell the problem is.
Might be condensate from the A/C, mixed with algae or some other green junk. Do you see this when you run without A/C?
Steve
when i left this morning check the radiator it was kind of low so i put some antifreeze in the reserve tank. I did not run my AC but when I stop and check later on still had a leak coming from i dont know where. Check under the hood couldnt see where it came from.
2001 Ford Explorer Eddie Bauer i have 59766 miles on it. Just came from downstairs the antifreeze that i put this morning still in the tank but still have a puddle under the same area. Looks like nothing in the radiator but there's little in there.
If the coolant shut-off valve for the heater core is in the same place as my '02 and '04 (right side close to firewall, has vacuum lines and heater hoses tied into it), that might be your problem.
Steve
Went to the dealer this morning this what they DIAG.
1.Check and Found Bypass Hose Leaking. Had To Install New Bypass Hose.
$110.00
I pass inspection on Tues. then went to Jiffy Lube for a quick oil change this when this problem occur I heard lot of peoples have problems when they leave Jiffy Lube. Well I will not go there ever again. Thanks for all the information fellas I should of look harder but I was very frustrated. Made my last payment in April and no real major problems.
Glad to hear you got 'er all taken care of. There've been lotsa horror stories in the Oil & Lube Forum in the past about problems when using these "quick-change" places; I either do it myself or have it done at the Ford dealer.
