Help Me
Old Jun 13, 2006 | 10:13 PM
hawaiiguy808's Avatar
hawaiiguy808
Help Me
OK HI IAM NEW SO HERE GOES I HAVE A 79 F250 WHEN I START IT IT RUNS GOOD BUT THEN YOU TAKE IT OUT FOR A DRIVE THEN IS STARTS TO BOG OUT AND THEN QUITS AND HARD TO START ORR IT WILL RUN GOOD FOR 15 MIN THEN ACT UP THIS IS WHAT I HAVE DONE SO FAR I REBUILT THE CAB,CLEAN PLUGS ,CAP,ROTOR AND REPLACE THE RUBER HOSE AT THE BACK OF THE TANK AND NEW FUEL FILTER HOSE AT FUEL FILTER LOOKS GOOD AND A NEW FLOAT TO DAY THE FULL PUMP WILL FILL S SMALL BOTTEL OF WATER IN 5 SECOUNDS (IS THAT GOOD) SO WHAT ELES?
Old Jun 13, 2006 | 10:44 PM
catalinagoose's Avatar
catalinagoose
Electronic ignition modules have failures similar to what you describe.
Old Jun 14, 2006 | 04:59 AM
Beast12's Avatar
Beast12
Hi and welcome to FTE! You should head on down to the 73-79 F-Series trucks forum. I am sure someone there would be more than happy to help you.
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
Scotty79
New Member Introductions
Dec 22, 2013 09:30 PM
jr1987
May 7, 2013 05:11 AM
CODT
May 1, 2009 10:45 PM
BLACK F 350
May 27, 2006 05:49 AM
Tom White
Nov 12, 2005 08:42 PM
