new and need help
Old May 5, 2013 | 05:57 PM
jr1987's Avatar
jr1987
new and need help
Hello, glad to be a new member. Could use some help, I have a 1987 f-250 4x4 5.0. It just died and will not start again, turns over fine, has fire from coil, fire from spark plugs, took fuel rail off has fuel from injectors. I have replaced the distributor module, high pressure fuel pump, new fuel filter, and cap and rotor. I'm thinking it jumped time or EEC computer is bad, but i'm far from being a mechanic. Any ideas would be helpful.
Old May 7, 2013 | 05:11 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Hi Jr, welcome to FTE!
You should post your questions about your truck in the tech forums. Members there will be happy to help you with your truck.
You might want to start your search here,,,,Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
Or maybe here,,, Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
Also FTE has a chapter for our IL members which you will find here,,, Illinois Chapter - Ford Truck Enthusiasts Forums
Take a minute and intoduce yourself to our local members.
Scotty79
New Member Introductions
Dec 22, 2013 09:30 PM
whitewaterman
May 7, 2013 05:23 AM
MIKEBOYCE94
Nov 18, 2007 04:10 PM
