Help With 6.9 Starting/Running
Old Apr 23, 2009 | 09:38 AM
CODT's Avatar
CODT
1986 350 Non-Turbo 6.9 starts, runs 3 seconds then dies. After long cranking starts and runs all day. Fuel filter new and remains full. Loosened injection line/no fuel. Could Inj pump be losing prime if so why and is there a repair w/o expensive pump replacement? Thank You
Old Apr 23, 2009 | 10:03 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You are getting air in the system allowing the fuel to drain back to the tank.
The typical spots for Air Intrusion are:
  • Injector Return Lines
  • Water Separator
A good write up for Injector Return Line Replacement
Water Separator, Either bypass or put a plug in the drain line.
Remember, Air molecules are smaller then Diesel, so just because it's not leaking fuel does not mean there is no air intrusion.
-Enjoy
fh : )_~
Old Apr 23, 2009 | 10:09 AM
Festus Hagen
Methanoholic
I guess if I would read the Forum name .... I would say!
Welcome to FTE.
You would get better response in one of:
  • 1980 - 1986 F100, F150 And Larger F-Series Trucks
  • Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
-Enjoy
fh : )_~
Old Apr 23, 2009 | 10:47 AM
CODT's Avatar
CODT
Thank You "FH" (Great Character On Gunsmoke)
"FH" Thanks for the help, on my 6.9. On the rare occasion, it will start and stay running but mostly not. Is there some way of "Priming" the inj pump manually with out breaking a line ie: drill/tap a small hole in pump chamber, non-pressure side and add fuel allowing air to escape through loosed inj line? Also, is there a diagram on line of pumps internals?Thanks Again For The Help As I've Got To Get Her Started TodayCT
Old Apr 23, 2009 | 10:56 AM
Festus Hagen
Methanoholic
You're welcome.
You should only need to bleed at the Filter housing schrader valve.
And like I said, Please post these questions in the appropriate forum, you will get much better response.
-Enjoy
fh : )_~
Old May 1, 2009 | 10:45 PM
jkula31's Avatar
jkula31
cut the line and put a check valve in
trike1946
Jun 23, 2013 01:24 PM
corvette99
New Member Introductions
Sep 21, 2008 10:17 AM
Winsted Organics
Oct 10, 2006 04:44 PM
funkedupford84
Jul 20, 2006 05:12 AM
