Making progress, electric speedo working
Old Jun 13, 2006 | 07:39 PM
workingdog's Avatar
workingdog
Just in case someone is looking for a similar solution, I'm entering this so it can be found in the archives.
An NP204 or NP205 has a speedo hole into which you can plug a speed sensor from a late 80's T-Bird. That sensor will drive an electronic speedometer. If you steal one from a junkyard make sure you take the connector from the wiring harness as well.
I think this sensor will also go right into a C6 as well, but if you have a transfer case the speed from the C6 won't be correct in low gear.
Peter
Old Jun 13, 2006 | 11:34 PM
Ford_Six's Avatar
Ford_Six
Cool, thanks for the tip.
I was trying to think of ways to have a speedo pickup in my truck when I go to the electronic speedometer, much better than putting on a magnet setup or making a tone ring.
ErrorS
1978 - 1996 Big Bronco
May 13, 2011 08:51 PM
idaho86f150
Mar 11, 2008 07:50 AM
workingdog
Apr 3, 2006 10:08 PM
Peter Bowler
Aug 11, 2003 05:22 AM
Ed T
Offroad & 4x4
Oct 17, 1999 04:18 AM
