Broken Header Bolts
Old Jun 28, 2006 | 04:47 PM
mike2112's Avatar
mike2112
Talking duplicated post
oops, I already posted a response and can't figure out how to delete this duplication.
Old Jun 28, 2006 | 05:19 PM
mike2112's Avatar
mike2112
Wink
Originally Posted by Nathane
WD40 is NOT a penitrating oil, or effective luberciant... U wouldnt have broken them off if you had done nothing to them.
PB is the best stuff out there for this type of work... High flashpoint, and low residue... Just do it...
~Nate
Without disparaging PB, WD-40 IS a penetrating oil. I've used WD on everything from nuts and bolts around the house, to truck parts, to parts on F-4 fighter jets. I'm in no position to compare the penetrating, cleaning, or lubricating properties, or the flash points for that matter, of the two products, but I do know from over 25 years experience that WD-40 works quite well for its stated and intended purposes, which is a penetrating, cleaning, and lubricating petroleum product. Anyway, that's just my opinion.
Old Jun 29, 2006 | 07:08 PM
Nathane's Avatar
Nathane
That may be true, but what I'm saying is that 9 times out of 10, PB has worked much better for me as a penitrating oil.
It's not a lube, but it's a better penitrating oil then wd can ever be.
WD-40's a water displacing agent, that happens to work as a lube, light pentrating oil, and cleaner (pb's good, but it has a smell)
PB is more specified, WD works OK on more stuff
~Nate
Old Jul 1, 2006 | 09:24 PM
fordf150guy's Avatar
fordf150guy
the motor as a whole has smoothed out since installing the new exhaust. it seems to pull a little higher than it used to, and i have no problems spinning 35" tires in 1st. for me, yes it was worth it because my old exhaust was kinda sacked. my seat of my pants dyno feels like there is a little more grunt down low + the added smoothness...but i wouldn't consider it a huge jump in the power department.
BigRiggs
1997 - 2003 F150
Dec 22, 2013 09:28 PM
gopher2
20
Sep 18, 2013 08:17 PM
dixiestripes351
1997 - 2003 F150
Apr 14, 2011 05:51 PM
JeffNJF150
Mar 31, 2011 08:47 PM
exploranger
1997 - 2003 F150
Dec 27, 2009 11:57 PM
