headers / gt40 head removal
Old Aug 27, 2013 | 02:04 PM
gopher2's Avatar
gopher2
96 302
have some headmen longtube headers i want to install
it looks like one of the bolts on the drivers side is broken off
also the passenger side looks very hard to get to the bolts
all are super rusty
i could goto parts galore and pull some gt40 heads for $36!
how much work is it to pull the heads off?
any idea what size sockets / special tools i will need to bring to the junkyard?
Old Aug 28, 2013 | 02:55 PM
gopher2's Avatar
gopher2
anyone ?
Old Aug 29, 2013 | 10:01 PM
1993_f350_2013's Avatar
1993_f350_2013
Im interested too!
Old Aug 29, 2013 | 10:24 PM
nflfreak43's Avatar
nflfreak43
Here ya go..
http://www.ford-trucks.com/forums/11...l#post10894549
Old Aug 29, 2013 | 11:44 PM
gopher2's Avatar
gopher2
well that answers my question !! changing heads is way more work then i feel like doing. Thanks for the reply
Old Aug 29, 2013 | 11:53 PM
nflfreak43's Avatar
nflfreak43
Ain't to bad.. Can be done in a weekend if ya have all the stuff and don't run into major snags.
Old Sep 17, 2013 | 04:57 PM
gopher2's Avatar
gopher2
okay.. well i got the manifolds off
does anyone know what size bolts i need to get for the 302?
are the locking ones worth the extra money?
Old Sep 17, 2013 | 05:32 PM
Bob Gervais's Avatar
Bob Gervais
3/8-16x1" long bolts. The locking bolts are well worth the money. Percy's dead soft aluminum gaskets are a good investment too.
Old Sep 17, 2013 | 09:57 PM
gopher2's Avatar
gopher2
my headers are about 3/4 as thick as the stock manifolds, will hole clearance be an issue?
Old Sep 18, 2013 | 03:18 AM
Bob Gervais
I'm guessing your header flanges are the standard 3/8 thick, so no, you won't have any issues.
Old Sep 18, 2013 | 03:28 AM
gopher2's Avatar
gopher2
thanks bob!
Old Sep 18, 2013 | 06:53 AM
Bob Gervais
No problem! I wish I had sprung for the locking bolts when I installed my shorty headers. I'll be changing the regular bolts out soon.
Old Sep 18, 2013 | 09:24 AM
nflfreak43's Avatar
nflfreak43
i've got the reg bolts that came with my shorties in my long tubes...
no problems here.. just make sure theyre tightened down good on original firing and after 1 heat cycle retighten.. and you should be good from there..
Old Sep 18, 2013 | 10:30 AM
gopher2's Avatar
gopher2
so now i am ****ed
i got all the bolts out of the passager side no problem
the drivers side is different story.
1 bolt broke off at head
the other was missing, already rusted off and broke at head
now i broke off the easy out in the head... ****.
is here
(n option to upload to this site?)
So now i guess i have to pull the heads?
Old Sep 18, 2013 | 10:37 AM
Bob Gervais
The PO of my truck did the same exact thing, to three bolt holes. What worked for me, was to heat the ez out cherry red, then strike it with a punch. I eventually broke it enough to get the pieces out, then carfully drilled out the old bolt, and retapped. I did have one hole though, that I had to use a heli coil in. It's worth a shot...
