Sponsored by: Auxito
check engine light... p401 code
Old Jun 11, 2006 | 02:14 PM
boogie's Avatar
boogie
okay, i have replace the egr valve, cleaned the throttle body, replaced the dpfe sensor, now what should i do to get rid of this dam code. i have tried everything... please help
Old Jun 11, 2006 | 07:29 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Sounds like the EGR tube may be clogged. Try this, with the engine idling, apply vacuum to the egr valve, if the engine stumbles or dies, then it is working. If the idle doesn't change, then the tube or port in the intake is probably clogged.
Old Jun 11, 2006 | 07:57 PM
boogie's Avatar
boogie
i have already tried this and it seems to be working... thats why im so puzzled? dont know what i should do now....
Old Jun 11, 2006 | 09:48 PM
LxMan1's Avatar
LxMan1
Perhaps maybe you got a bad sensor? I am assuming that you bought a new one.
Old Jun 11, 2006 | 10:11 PM
vloney's Avatar
vloney
you still need to clear the code. It will clear by itself eventually, but oughtta do it now just to make sure there is no other problems.
Old Jun 11, 2006 | 10:23 PM
boogie's Avatar
boogie
i put a new sensor on and i did clear the code after putting it on and cleaning everything intensely. i drove for almost 45 miles and the light came back on... any ideas?
Old Jun 11, 2006 | 10:29 PM
vloney's Avatar
vloney
pm me with your vin
Old Jun 12, 2006 | 06:55 AM
projectSHO89's Avatar
projectSHO89
Did you actually remove the throttle body and clean the EGR ports?
That is what LxMan1 is referring to.
Steve
Old Jun 12, 2006 | 11:45 AM
boogie's Avatar
boogie
yes i did.. i took everything apart and cleanded the ports and all...
Old Jun 12, 2006 | 12:46 PM
vloney's Avatar
vloney
check the vacuum harnesses near the battery. If battery acid spills over onto them, it will cause this condition.(ssm 10787) oh yeah, you have an outstanding recall on your cruise control.
Old Jun 12, 2006 | 12:52 PM
boogie's Avatar
boogie
i have a dry cell red top optima... and i know about that recall, thanks man
Old Mar 12, 2010 | 03:25 AM
chris5301's Avatar
chris5301
i havent checked my vacuum hoses by the battery, but if its not that, then what else could it be?
kbf1961
Oct 17, 2015 10:05 PM
bkvanbek
Oct 16, 2014 08:31 PM
thunderbird1986
Oct 21, 2013 07:30 AM
BIGLEVY
Sep 11, 2013 11:48 AM
broncorif
Mar 23, 2010 06:20 PM
