code p2197
Old Oct 19, 2013 | 03:00 PM
thunderbird1986's Avatar
thunderbird1986
code p2197
02 sensor signal stuck, lean bank 2 sensor 1.
i have replaced with a new o2 sensor and this code came up. the code was gone for about a month and now back. what could be the problem.
thanks
Old Oct 19, 2013 | 04:26 PM
JWA's Avatar
JWA
What brand O2 sensor did you use? Anything other than OEM or Motorcraft seems a bit incompatible with Ford ECM's which might be at the root of this return.
Is the connector or any wiring visibly damaged, perhaps not making good contact along its length?
Old Oct 20, 2013 | 08:24 PM
thunderbird1986
its a bosh from auto zone
Old Oct 21, 2013 | 07:30 AM
JWA's Avatar
JWA
Bosch O2 sensors from anywhere have been known to cause problems in Fords. For most sensor replacement its always highly recommended using OEM or Motorcraft.
More specific info might be found here: Modular V8 (4.6L, 5.4L) - Ford Truck Enthusiasts Forums
Tominky
2009 - 2014 F150
Oct 3, 2018 08:39 PM
mizzourover
2009 - 2014 F150
Apr 14, 2015 09:28 AM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
BrianA
1997 - 2003 F150
Jul 17, 2012 06:14 PM
elrodalonzo
Apr 17, 2006 10:14 AM
