I have a 04 scab lariat. When the truck is cold the cruse will work. After 5 minutes after the truck warmes up it shuts off if i hit the resume button it will work for 2 seconds then thats it it wont work untill the truck sits and cools down then the same thing all over again. The tranny has been serviced with filter and other than the cruse it seems to run fine. I checked for trouble codes with my elmscan and found none. I have 56000 miles on it. If there are any ford techs out there that have maybe seen this before ore any one else with any ideas your help would be appreciated. Thanks
check the cruise deactivation switch under the dash above the brake light switch, it works exactly opposite of the brake light switch, you should have power on both sides of that switch when not pressing on the brake
You might want to take it in and have the Cruise Control Mod done as it is to your benifit. It has been reported that fires have started in Cruise Control circuit even with the ignition off and vehicle unattended and it's a simple dealer modification and it's at no cost to you.
