overdrive unit
Old Jun 9, 2006 | 09:02 PM
robertpecor's Avatar
robertpecor
overdrive unit
i am looking for a overdrive unit for 1950 f3 it has a four speed with a 8ba v8 flathead can you help me out thanks
Old Jun 9, 2006 | 10:43 PM
AXracer's Avatar
AXracer
You could put in a T5. Or there are tailshaft OD units made by a couple different manufacturers, but I wonder how long you'll be happy with a non syncro tranny on the street.
Old Jun 9, 2006 | 11:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If you are talking about the Borg-Warner OD that was used on cars and on F-1's from 53-on, I don't think it would work for you. First of all, it wasn't designed for something as heavy as your F-3. Second, as far as I know, it was never used with the HD 4-sp, so there wouldn't be any mainshafts with the proper modifications to mate with the OD.
If you are going to use your F-3 as a truck, and haul stuff up to its GVW, you should probably look for a modern Ford 5-sp. If using the T-5, you'd want the World Class model for its greater strength. On the other hand, fully loaded, I doubt the 8BA is going to pull an OD ratio. That's one reason it doesn't have one!
bkbauer1955
16
Dec 28, 2012 07:34 PM
ken_r_mer
Sep 11, 2010 07:03 AM
1977RangerShortbed
Nov 19, 2008 01:50 PM
Ford79
Oct 20, 2008 02:53 PM
ddurant
Jul 18, 2003 06:47 PM
