Doug Nash Overdrive Unit Question
Old Oct 19, 2002 | 10:43 PM
Ford79's Avatar
Ford79
Old Oct 23, 2002 | 04:47 PM
mattv1's Avatar
mattv1
Does anybody know anything about a doug nash overdrive unit for a c6 transmission. My friend has one for sale, apparently it just bolts to the tailshaft??
Old Oct 23, 2002 | 06:37 PM
77460ford's Avatar
77460ford
Post Doug Nash Overdrive Unit Question
I did a quick search and copied the following:
"The US Gear Dual Range unit was originally designed and initially built by Doug Nash Transmissions several years ago. Internally it's a very conventional-looking husky two speed gear box that uses an electric servo motor to shift between its two ranges. It stays in the range it's left in, even in reverse or with the engine off. Because of its basic gear box design, it can be configured as a conventional overdrive or as an underdrive. (Older models at least can be reversed back and forth - but two of the gears need to be replaced to do that. There's also the issue of putting new gears in with worn. Also keep in mind that US Gear reportedly doesn't support the Mile Marker and Doug Nash manufactured units - those with serial numbers below 20,000 - if you're thinking about buying a used unit.)"
I don't know how accurate the information is but the RV site I found it at looked good. Hope this helps.
John
Old Oct 27, 2002 | 09:04 PM
elliott's Avatar
elliott
Check with US Gear, they will give you all the answers. Elliott
Old Oct 20, 2008 | 01:51 PM
Northwest ohio's Avatar
Northwest ohio
I have what I am told is a Doug Nash unit it has a DNE2 cast in the side then R1A1 by the serial of 001464 casting no 71-8003 on the case and 72-80014 on the adaptor its for a C-6 but I was wondering if its an overdrive or underdrive unit I called USGears but they wern't much help Thanks
Old Oct 20, 2008 | 02:53 PM
85e150's Avatar
85e150
See similar post by N.W. O.
Google "doug nash overdrive" and get:
Doug Nash Overdrive Problem Page
and lots of others. Some problems, may be fixable, no support from US Gear from what little I read on the search.
Good luck.
pm042070
Sep 25, 2013 12:55 PM
robert7249
Jun 25, 2012 10:31 PM
Diesel JD
Jul 15, 2008 05:21 PM
Art
All Things Towing
Mar 8, 2005 09:51 PM
banjopicker66
May 22, 2004 07:54 PM
