need coolant
Old Jun 8, 2006 | 03:51 PM
hedhntr's Avatar
hedhntr
need coolant
Its time to change my coolant and I remember seeing something about the color of the coolant, seems like I had to put the same color in. Well my coolant looks orange so does anybody know where to get it and how much I need? Thanks
Old Jun 8, 2006 | 04:13 PM
Vijay's Avatar
Vijay
I had similar question last week see link .
If have details/procedures (with photos) of how to drain the old coolant and fill in the new coolant let me know too.
Old Jun 8, 2006 | 04:19 PM
aklim's Avatar
aklim
Orange?? Not good. Somebody screwed up. Shouldn't it be green or yellow? What year? You might be able to use the Gold coolant and not have to add FW15 to it every 15000. That is what I did. Have it flushed throughly and then flushed again. Then blow it out and use distilled water and the Gold coolant
Old Jun 8, 2006 | 06:45 PM
Muktown's Avatar
Muktown
i also have a year 2000 and with 200,000 miles on it i will only put in the low silicate green antifreeze. if i got the truck with less miles i would consider switching to the gold or an elc but with that many miles on it im not going to switch. if you do use the green coolant make sure you add the sca to it
Old Jun 8, 2006 | 07:17 PM
clux's Avatar
clux
Color means nothing. Chrysler's orange coolant is the same as Ford's gold (Zerex G05) but not the same as GM's orange dexcool. Since you don't know for sure what kind of coolant you currently have, you should do a thorough flush of the system, then refill with whatever you want. I personally started with green low silicate coolant, got tired of monitoring sca's and switched to G05 for 70,000 miles. Just flushed last weekend and refilled with Peak's Global Final Charge, which is supposed to be no maintainence for 3 years, 300,000 miles, or 6000 hours.
Old Jun 8, 2006 | 09:59 PM
1nascar24fan's Avatar
1nascar24fan
Aklim,, I have the orange also from factory!
Old Jun 8, 2006 | 10:04 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Cool, so that final charge stuff ya can buy at Wally needs no additives right?
Old Jun 8, 2006 | 10:11 PM
clux's Avatar
clux
I don't know about the wal-mart part, but Peak Global Final Charge is maintainence free, yes. Cat ec-1 rated coolant is really what I was looking for, Peak just happened to be what I found.
It's also kind of a cherry orangish-red colored.
Old Jun 8, 2006 | 10:13 PM
Tenn01PSD350
Wish I had written it down, but it is big truck diesel stuff premixed and ready to go. Says not to add anything and lists all the diesel engine manufacturers on the back as for suitability.
Old Jun 8, 2006 | 10:19 PM
clux's Avatar
clux
Something like this:Peak
Old Jun 8, 2006 | 10:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That is correct. It carries the CAT EC-1 as well as the ASTM D-6210 rating for heavy duty use without SCA's.
Old Jun 8, 2006 | 11:04 PM
Tenn01PSD350
Thanks Scott, gonna buy some.
Old Jun 8, 2006 | 11:16 PM
aklim's Avatar
aklim
I thought they only had green and yellow but if they had orange, it is something I didn't know.
Old Jun 9, 2006 | 06:29 AM
Calli's Avatar
Calli
Aklim. I also have a '03 Mountaineer which has the orange coolant. Even the owner's manual just refers to green or yellow. Maybe someone had an extra bottle of food coloring??? Who knows? Carroll
Old Jun 9, 2006 | 11:56 AM
Vijay's Avatar
Vijay
Thumbs up
Found this article . Very helpful...
If you have green color coolant, every time you replace it, you have to make sure that it has 50% green coolant and 50% distilled water. If you have yellow coolant just add as it is. Do not mix yellow and green. Now I need to figure out how to drain the coolant…any idea?
