Need help regarding coolant
when all I need is to bring up the level of the coolant to proper level.I went ahead and picked up {“PITT PENN” premium permanent antifreeze, summer coolant}. Do I have to mix this with water or is it ok to add it directly to the coolant tank
. The level of Coolant in the tank is slightly below min right now.
Cooling system maintenance for these vehicles is not as simple as merely adding any old antifreeze. Their are some important issues such as Supplemental Coolant Additives which you need to address.
At a minimum, could you please list your model year, engine and build date? It might even help if we knew which Ford plant built your truck.
Thanks!
Ed
Premium Engine Coolant
Green-colored, conventional, ethylene glycol based, universal formulation for use in gasoline and diesel engines
Approved for engines with aluminum radiators and/or aluminum heads as well as conventional engines
Provides year-round antifreeze, antiboil and corrosion protection
Provides year-round protection in both hot and cold climates. Provides -35°F winter to over 250°F summer system protection when used in the recommended 50% mix with
Do not use in model year 1999 and forward Cougar and Electric Vehicle Ranger
Do not mix this coolant with systems originally equipped with any orange-colored, extended-life coolant such as Motorcraft® Specialty Orange Engine Coolant, meeting Ford Material Specification WSS-M97B44-D or the yellow-colored, extended-life coolant Motorcraft® Premium Gold Engine Coolant, meeting Ford Material Specification WSS-M97B51-A1
Yellow-colored, extended-life, ethylene glycol based engine coolant for use in gasoline and diesel engines
Only use where specified. Do not mix this product with systems originally equipped with any green-colored, conventional engine coolant such as Motorcraft® Premium Engine Coolant, meeting Ford Material Specification ESE-M97B44-A or any orange-colored,extended-life engine coolant such as Motorcraft® Specialty Orange Engine Coolant, meeting Ford Material Specification WSS-M97B44-D
Heavy-Duty Cooling System Additive (vc-8)
For use in heavy-duty diesel engine cooling systems only
Designed to replace the additives depleted when coolant is used for extended drain intervals
Recommended for use in 7.3L Power Stroke® diesel engine
Use only where specified
FleetPride lifetime condensed.
It is not cheap at $28 a gallon, but I am getting discount and on the side of having perfectly balanced SCA it is mixable with all other coolants, so no full flushing is necessary.
Did I mention it it lifetime?
BTW I also added the coolant filter. The housing was $26, the filter with SCA chemicals in it $37.
Thanks!
