I just dropped my newly rebuilt 302 in my 87 F150. The problem is that I turn the key and nothing happens. All the wires are hooked up properly to the starter, thats been cleared up by a previous post. Any suggestions?
Check all your battery grounds, including the ones hooked up to the engine block, firewall, and Batt. grounds. Since a new motor was installed. recheck all straps.
Also, jump the starter solenoid on the pass. fender with a screwdriver shaft and see if power at it, or at least turns motor over.
