nothing
Old Jul 6, 2004 | 10:11 AM
jeter's Avatar
jeter
nothing
i have a 1993 f250. the other day i got in my truck and turned the key and nothing happened not even a "click". could it be the ingnition switch.
Old Jul 6, 2004 | 11:22 AM
JBD94F250's Avatar
JBD94F250
Are the glow plugs cycling fine, batteries charged?
Check the selenoid.
Old Jul 6, 2004 | 11:24 AM
fordman428's Avatar
fordman428
if your positive the batterys good and you didnt leave the lights on etc.. it could be the ignition switch, however a couple weeks ago i got in a buddys 90 F250 diesel and turned the key and nothing happened and it turned out the rod that runs from the ignition switch down the steering column to another switch had broke. your prolly wondering what the heck im talking about, but yes a 3/8 rod starts your diesel, it could be that if its not the ignition switch. just my .02 cents worth, btw if it is that rod you have to order it from ford for $9.99. good luck
Old Jul 6, 2004 | 12:08 PM
fellro86's Avatar
fellro86
it is possible for a fusible link to have gone, but if it did, you need to know why.
Old Jul 6, 2004 | 07:51 PM
Dave Sponaugle's Avatar
Dave Sponaugle
When you say nothing, do you mean nothing, it did not crank?
Or do you mean nothing, no radio or wipers or lights or anything else?
Old Jul 7, 2004 | 06:49 AM
jeter's Avatar
jeter
well, today i got in it and it did the same thing except i held it in the on position for a second and it started. everything else works fine when i turn the key on.
Old Jul 7, 2004 | 07:07 AM
fellro86's Avatar
fellro86
sounds like it well could be the ignition switch.
Old Jul 7, 2004 | 09:50 AM
ditch witch's Avatar
ditch witch
If it's a manual transmission you gotta be sure to have the clutch all the way down to activate the safety switch!
Old Jul 7, 2004 | 10:11 PM
d dueck-4's Avatar
d dueck-4
I am a ford tech and it is a comen problem with the conection at the starter,the cable gets corroded and you sometimes have to hold the key in the start possition to warm up the connection and then it starts,try cleaning all the connections inc battery cables and there is a very good chance that you wont see me.
Old Jul 7, 2004 | 10:21 PM
Manitoulin's Avatar
Manitoulin
The best thing to do is a Volt drop test on the starting system.
http://www.fluke.com/application_not...AGID=1&SID=103
fordtruck661
18
Oct 31, 2012 02:16 PM
mrwrench
Oct 5, 2010 08:48 PM
crestfallinman
Dec 4, 2008 04:51 PM
ilo9
Oct 2, 2007 07:06 PM
dammford
1978 - 1996 Big Bronco
16
Oct 26, 2004 09:35 AM
