Got a problem?
Old Oct 13, 2009 | 02:48 PM
wooden79's Avatar
wooden79
Got a problem?
My 05 F150 wont start. Everything works fine but when i turn the key nothing happens. I removed the starter and had it tested but it was ok.
Prior to the truck not starting, for a couple weeks I would go to start it and nothing would happen but after a couple of turns of the key it would start. Now it won't. Any suggestions on what could be my problem. I already check fuses. Thanks
Old Oct 13, 2009 | 02:51 PM
Kirbys73F100's Avatar
Kirbys73F100
possible loose battery connection
Old Oct 13, 2009 | 06:04 PM
wooden79's Avatar
wooden79
No I checked them. They were nice and clean and tight
Old Oct 13, 2009 | 06:09 PM
wildcard30's Avatar
wildcard30
Bad battery? Did you have it tested?
Old Oct 13, 2009 | 06:32 PM
n5926g's Avatar
n5926g
If the battery and starter check out,the problem is likely in the ignition switch..especially since you could try it a few times,and it would work before...
Old Oct 13, 2009 | 07:00 PM
screwy's Avatar
screwy
Check the relay too.
Old Oct 13, 2009 | 07:38 PM
g_k50's Avatar
g_k50
Try starting it in Neutral. If it starts it's the safety switch.
Old Oct 14, 2009 | 05:04 AM
06supercrew's Avatar
06supercrew
I remember having read a post on a thread somewhere on this site about the cable from the battery to the starter going bad. Have you checked the power to the starter from the battery?
Old Oct 14, 2009 | 06:09 PM
air1jpg's Avatar
air1jpg
You may want to check that little red security light ontop of the dash. The security module may not be reading your key and disabling your starter.
Old Oct 15, 2009 | 10:47 AM
tbear853's Avatar
tbear853
I was just scrolling down to suggest neutral safety switch ...
... never thought of this problem.
Try another key maybe?
Old Oct 15, 2009 | 04:41 PM
wooden79's Avatar
wooden79
thanks for all the suggestions. I still haven't figured it out. I changed the ignition switch and that wasn't it. I tried my spare key and the security light on my dash is on.I do have power to the starter but only on one side. Does anyone have any other suggestion i would love to hear them. I'm out of ideas and sick of working on it. I will probably end up taking it in unfortunately. Thanks again
Old Oct 15, 2009 | 09:58 PM
air1jpg's Avatar
air1jpg
Did you check to see if the starters' wire to ground is tight and clean?
Old Oct 16, 2009 | 12:07 AM
shorebird's Avatar
shorebird
The starter grounds through the bolts to the block.
The key transponder sensor may have failed. It is mounted in the column. If it failed it will not read the key resulting in the problem you are having.
Old Oct 16, 2009 | 12:09 AM
monkee boy's Avatar
monkee boy
probably a problem in the column, when the key turns in the ignition a rod also turns(supposed to turn but the problem is that it doesn't turn enough) thus not turning the electical portion of the system. if your good you can take off the column cover and pop off the electrical portion of the ignition(left side of column straight across from the ignition switch) and turn it with a screwdriver, truck should start with key in the ignition in the on position(to allow the anti theft portion of the ignition system to work). sounded good when i was thinking!
Old Oct 16, 2009 | 12:53 AM
SMok's Avatar
SMok
Have you tried checking codes? This may help point you in the right direction. I have seen the pcm relay go bad a couple of times. When you got to pull codes, there will be no communication with the pcm. This will mean that your pcm is probably not getting power.
To test, all you need to do is swap the upper 2 relays in your fuse box at the passanger side kick panel. I have only seen this happen a couple of times, but it may work.
smoores250
Jan 7, 2010 06:30 AM
BlackFX4Screw
2004 - 2008 F150
Dec 21, 2008 08:52 PM
shatfieldj
2004 - 2008 F150
Mar 23, 2008 04:57 PM
brocobilliam
1978 - 1996 Big Bronco
16
Jan 3, 2006 11:34 AM
bowez
Apr 18, 2003 01:32 PM
