Sponsored by: Auxito
"Squeek" from drive shaft?
Old Jun 6, 2006 | 04:31 PM
85 F-350CrewCab's Avatar
85 F-350CrewCab
ive been trying to find out what this squeek is coming from on my `03 F150, i thought it may be my rear brake pads squeeking but with me kneeling near the truck and having someone pull forward slightly then press the brake it seems to be coming from the drive shaft area
anyone ever have this problem? im lost
Old Jun 6, 2006 | 08:00 PM
Dustin1690's Avatar
Dustin1690
Yeah i have the same problem except though its on my parents van 2004 Kia Sedona i know it aint a ford but oh well im pretty sure its the brakes (at least on my van) its an on off thing when you brake slow it does it and then when you slam hard on them they dont squeak we took it to the dealer and they said its fine and supposed to do it or something like that yeah im lost too im curious what causes this problem.
Old Jun 7, 2006 | 12:29 AM
ksdunlap's Avatar
ksdunlap
if it has drum brakes it could be brake dust built up but it sounds like you have got a ujoint dry and needs replaced,
Old Jun 7, 2006 | 12:35 AM
Pony Power's Avatar
Pony Power
I'm going with the u-joints also.
Old Jun 7, 2006 | 06:22 PM
85 F-350CrewCab
i have 4 wheel disc
also i didnt believe a u joint would make that noise but i guess for how cheap it is to replace them it wouldnt hurt a bit
Old Jun 7, 2006 | 07:06 PM
Diesel Man 03's Avatar
Diesel Man 03
I have a squeak in my f250 but it is coming from the front axle seals.Ford has replaced them but after 400 miles the squeak is back.The squeak is not steady but only occasionally.Ford knows about this but doesn't have an answer.They said if they come up with a fix they will let me know.
Old Jun 7, 2006 | 08:19 PM
85 F-350CrewCab
my pinion seal seems to be bad, could that be anything to do with it?
Old Jun 9, 2006 | 12:43 AM
DeanG's Avatar
DeanG
I have an 01 SCrew that had the same "squeak" you describe. Does the frequency of the squeak change with vehicle speed? I pulled my driveshaft and found the ujoints all dried up and so replaced them. Squeak is gone.
Old Jun 9, 2006 | 07:18 AM
Country4.2's Avatar
Country4.2
I had the same problem on my 1992 F-150. I replaced the u-joints and problem solved.
samohtman
1997 - 2003 F150
Nov 8, 2009 09:17 AM
78crewcabjohn
May 12, 2008 02:13 PM
wmwbutler
Dec 3, 2004 12:00 PM
dblakney
May 18, 2004 08:28 PM
