Driving Light's
Old Jun 4, 2006 | 12:11 AM
pbjohns's Avatar
pbjohns
Talking Driving Light's
02 exp stock v6, did not come with the driving light's . Other than going to a dealer can I get the light's/mounting's at a cheaper cost. How is the wire harnes hung? What about the control switch? Any info will help..
Old Jun 4, 2006 | 06:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 4, 2006 | 03:34 PM
stealthone's Avatar
stealthone
Post 10 steps to install aux - driving - fog lamps
A good source for things like lights is eBay. Unfortunately the 02 is different than mine so I can not assist with the actuall wiring diagrams. However, the general installation is like this (recommended wire and fuse sizes based on two 50W lights):
  1. Mount the lights
  2. ground one wire from each bulb
  3. mount a relay under the hood
  4. run a fused (10 amp) wire (16 ga) from the battery to the common terminal of the relay
  5. add a jumper wire (18ga) from the relay common terminal to one of the coil terminals of the relay
  6. run a wire (16ga) from the normally open contact of the relay to the remaining wire for each of the driving light bulbs
  7. mount the on-off switch in the cabin
  8. run a wire (18ga) from the remaining coil contact on the relay to one side on the on-off switch in the cabin
  9. run a wire (18ga) from the remaining on-off switch contact to ground
  10. test the lights - you are done!
I hope that helps!
sand1
Sep 2, 2014 09:39 PM
rodsterman
Feb 21, 2004 12:27 AM
f_pumillo
Nov 15, 2002 10:46 AM
buzzard
Nov 12, 2001 10:06 PM
F117X
Oct 7, 2001 11:56 AM
