cel the same as ses light?
Old Sep 1, 2014 | 07:19 PM
sand1's Avatar
sand1
Service engine soon came on while driving is that light the same as check engine light?
Old Sep 1, 2014 | 07:26 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yeppers....
Old Sep 1, 2014 | 07:56 PM
Pikachu's Avatar
Pikachu
You might also see MIL, malfunction indicator light.
Old Sep 1, 2014 | 10:01 PM
sand1's Avatar
sand1
I guess time for a scan
Old Sep 1, 2014 | 10:06 PM
sand1's Avatar
sand1
Truck started to hesitate around 40 mph then it would smooth out after that any ideas anyone
Old Sep 2, 2014 | 01:26 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The code will give the best clue. Just guessing without it...
Old Sep 2, 2014 | 01:18 PM
sand1's Avatar
sand1
Had it scanned but showed no codes cuz light was off would air filer reset button cause it to go on I pushed it in and I heard a click so I assume it reset air filtering on side of box
Old Sep 2, 2014 | 01:30 PM
David7.3's Avatar
David7.3
Na that wouldn't do it, it's a soft code. Meaning it didn't store in memory, so you have to scan it when the light is on, don't shut it off just go and scan it or wait till it gets worse or drive it long enough to store the code, then you can retrieve it.
Old Sep 2, 2014 | 02:47 PM
ToMang07's Avatar
ToMang07
^No. That's not how it works.
If the light flashed on....there IS a code stored. You need to find a better quality scanner.
Old Sep 2, 2014 | 09:39 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
What Tom said ^^^
The scanner you are using is not suitable for our "special" trucks.
Rusty_S
Aug 26, 2015 08:51 PM
nightowl263
Dec 20, 2011 10:45 PM
tenptbuck7mmmag
1997 - 2003 F150
May 6, 2008 10:18 PM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
rvfiver
May 16, 2003 07:02 PM
