Sponsored by: Real Truck
Front axle u-joint
Old May 25, 2006 | 03:47 PM
Gnikhog's Avatar
Gnikhog
Front axle u-joint
In the middle of my ball joint replacement I now see that my front axle shaft universal is dry/squeaky and needs to be replaced. There are no snap rings on these u-joints, so do I just press them out? They are not recessed and in fact they look like the caps protrude from the yokes about 1/16". I would like to believe that replacement of the whole axle shaft assembly is not required! Any pointers?
Old May 25, 2006 | 03:52 PM
texcan's Avatar
texcan
would like to know also as this may be my problem too!
Old May 25, 2006 | 04:00 PM
biz4two's Avatar
biz4two
It is my understanding that the axle u-joint is replaceable just like the drive shaft u-joints. Same procedure really.
Large socket on one end.
smaller socket on the other end
Large c-clamp
That should do it! OF course..."IF" I am wrong...I am sure someone will point it out.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old May 25, 2006 | 05:29 PM
BFR250SD's Avatar
BFR250SD
biz
Hehehehehehehe!!!
Old May 25, 2006 | 05:38 PM
captchas's Avatar
captchas
Guest
any one find the grease fitting yet. mine has one on each side .
Old May 25, 2006 | 08:41 PM
Gnikhog's Avatar
Gnikhog
captchas -you can be sure that my replacement U-joint will have a grease fitting as my replacement (Moog) ball joints do!
Old May 25, 2006 | 09:26 PM
99f350sd's Avatar
99f350sd
The good replacements are the one's with out the grease fittings by the way. They are more expensive and are usually lifetime warr. The joints have clips on the inside. Be carefull to bang them when removing because its easy to bend those parts..kinda have to shock them to keep them moving..when removing.
Dick
Old May 26, 2006 | 06:17 AM
texcan's Avatar
texcan
Great advise. But I found it. The front steering stabilizer. Thank god an easy fix.
Old May 26, 2006 | 02:30 PM
Gnikhog's Avatar
Gnikhog
Thanks 99f350sd for the clip location. There was so much rust and scale that they were completely hidden. As it turned out, I spent more time trying to drive out the old C-clips then pressing out the old u-joint! Hopefully the replacement will last as long as the original ~108K miles.
/John
Old May 26, 2006 | 03:09 PM
captchas's Avatar
captchas
Guest
in the midle of the steering hub take a look at the ujints on the axle shaft they may be like mine and have agrease fitting thats hard to see. right at the x on the joint a short. so that steering joint can be greased up.
for my ball joints and such i busted my back and drilled mine out and installed my own fittings 1/8 pipe thread
gunner121
Aug 4, 2011 09:13 PM
ramon1943
Apr 5, 2007 10:45 AM
fordor
Oct 22, 2006 11:41 AM
BroncRyder90
1978 - 1996 Big Bronco
May 7, 2004 08:36 PM
Kenny
Dec 15, 2003 06:43 PM
