ways to remove directional switch in steering column
Old Mar 9, 2002 | 01:51 PM
timl1's Avatar
timl1
is there any way to remove the directional switch from the steering column without cutting the wires on a 67 f-250. I would like to keepthe wires whole. Any response could help.
Old Mar 9, 2002 | 02:24 PM
karlsd's Avatar
karlsd
Yes. As you've probably discovered, there are seven wires on the switch. They terminate in two plugs under the dash -- five in one plug (it has six spaces, but one is empty) and two in the other. You can remove the wires from the plastic plugs by carefully depressing the metal tangs on the wire ends and sliding the out of the plug. There is a special tool made for this, but a very small flat-blade screwdriver works pretty well. Once the wires are out of the plugs, you can pull them through the column. Make sure to pull a spare wire or stout string through so you can attach it to the wires when you want to feed them back down through the column. Forget that last step, and you're in a world of hurt when you try to reassemble everything....
Old Mar 9, 2002 | 06:53 PM
Mil1ion's Avatar
Mil1ion
Here is what was talking about .
Another option is buying a special tool.
Lisle ,K.D.are two companies that make the special tool for about $8.00.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=2515&.jpg
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[b]Please Don't Ask Me Any Tough Questions [b]
[b]"I'm Saving My Memory For When I Develop Alzheimer's"[b]
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Mar 10, 2002 | 07:01 PM
LonnieD's Avatar
LonnieD
Dennis, the picture you sent looks noting like mine at all. I was playing with the spare 71 col I have ...I wanted to see how hard the switch would be to remove. Here's the deal, the wires are afixed to the turn switch, and are afixed to a switch plug that (two of them) they are almost square.. The funnel collar slides over the wires, and to remove the collar one would have to disconnect the wires from the switch or the block, if you remove from the block how in the heck do you find the correct place to replug them into the right slot on the block. There's no other way to get the wires out w/o doing that. Alos how in the heck do you get thsoe screws and buts back on the collar? Geesh I'm sure g;ad I'm using my spare first... alos the wires for the 71 are a combination of light green and white where the ones on my own 69 are red and black, Weird huh?
Lonnie
Old Mar 10, 2002 | 08:01 PM
evans's Avatar
evans
I think that pic is from a later model("78-"79) column. When I did my p/s swap I found that the wires were not only different colors but the switch was wired different from my '65 column to the column from the '72 so I put my switch from the '65 in the '72 column. Make a little diagram on paper to keep the location of the wires right. As for the bolts that hold the switch housing on, they can be a bear. It takes patience. Sometimes if you keep them pointed towards the outside of the column while tightening them they will grab better. Also check the condition of the slots where they go in. If it's been taken apart and put back together much they can get chewed up.
Mike/Ohio
Old Mar 11, 2002 | 08:12 AM
evans's Avatar
evans
Old Mar 11, 2002 | 09:09 AM
karlsd's Avatar
karlsd
Yup. That's what I said above. In the 67-72 trucks, the seven wires terminate in two separate plugs. One is a six-space rectangular plug that holds five wires (the 6th space is empty), and the other is a two-space plug.
Just take notes first. As stated above, you do need to remove the wires from the plugs. Before you do, note the color of each wire (each is a different color code, though you may need to clean them to be able to distinguish them) and where it goes in each plug.
Each of the seven wires is a different color. If you look closely, you'll see that each has a primary color and a stripe color. They may all look black if they are dirty or burnt, so clean them carefully.
yrots
Jan 25, 2021 11:36 PM
Bootlegger's Deluxe
31
Dec 14, 2015 10:34 PM
SJMaye
1997 - 2003 F150
Jul 3, 2014 08:46 AM
RotGrubestier44
13
Nov 20, 2012 09:45 AM
Les
Electrical Systems/Wiring
Jun 21, 2000 06:26 PM
