Sponsored by: Real Truck
f250 triton problem
Old May 22, 2006 | 08:52 PM
gvsu141's Avatar
gvsu141
f250 triton problem
i have a 1999 f250 superduty with the 5.4L triton with about 260k miles. sometimes at idle it will drop to about 400 rpms and starts loping. when given even just a little gas, it runs fine. it only will do this at idle. i was wondering if anybody has an idea on what this could be.
Old May 22, 2006 | 08:55 PM
gvsu141's Avatar
gvsu141
also, when hooked up to diagnostics it came back as running lean
Old May 22, 2006 | 09:35 PM
FortyFords's Avatar
FortyFords
Change the IAC (Idle air control valve),the most common problem of hunting idle.Was there codes in memory ?
could be a vacum leak also
Rich
Old May 22, 2006 | 10:42 PM
ReAX's Avatar
ReAX
yep IAC and pull the throttle body and wipe the gunk off of it.
Old May 23, 2006 | 06:27 AM
kenneBF250V10's Avatar
kenneBF250V10
I agree with FortyFords, try replacing the IAC valve for starters. You mentioned that a diagnostic test reported a lean condition, that definitely sounds like a vacuum leak. I had the same problem immediately after installing my supercharger. I don't remember exactly what the codes were, but it was running lean on banks 1 and 2. I tracked down the vacuum leak, fixed it, cleared the codes and the lean condition was gone. Check all of your vacuum lines for cracking and replace any that look bad.
Old May 23, 2006 | 08:44 AM
gvsu141's Avatar
gvsu141
thanks ill try that, but where is the iac valve located?
Old May 23, 2006 | 08:59 AM
kenneBF250V10
Right on the back of the upper intake. It looks like a little silver canister with about a 1 1/4" rubber hose and electrical connector coming off of it.
Old May 23, 2006 | 10:59 AM
FortyFords's Avatar
FortyFords
if you go to the top of this forum click on the sticky FAQ's a picture of it is in there
Rich
plumberboy76
Mar 14, 2013 04:33 PM
2001 f250
Nov 11, 2012 06:41 PM
Hall382
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 9, 2008 07:41 AM
Eric K
Dec 4, 2006 08:39 AM
camstack
Modular V8 (4.6L, 5.4L)
Sep 24, 2006 10:34 AM
