Leaf Spring Cross Reference
Old May 22, 2006 | 04:08 PM
SwampBilly's Avatar
SwampBilly
aight heres the question will a 1978-79 ford bronco leaf spring pack fit a 1977 ford f250 rear end? another question will a 1977 ford bronco leaf spring pack fit a 77 f250? links: 1978-1979 http://broncograveyard.com/bronco/c-116_springs.htm 1977 http://broncograveyard.com/bronco/c-39
Old May 22, 2006 | 06:08 PM
1975Ford's Avatar
1975Ford
try FTE member "springirl", she has the spring interface reference manual for all springs.
or you can compare the springs on national parts depot, suspension catalog.
Old May 22, 2006 | 06:16 PM
Jmudder79's Avatar
Jmudder79
The rear springs on your truck are narrower. 2 3/4" I think, than a 78-79 bronco, which has 3" leaves. Not sure about the early bronco leaves, I think they are 3" too. One thing you may want to try is different rear shackle setup. Me and my friend with a 77 250 were over a buddys house (chebby guy) when we noticed that a parts truck in his yard had the same width springs as his 77. And the shackles on the truck also dropped maybe 4-6" below the frame. He took the shackles and mounts off the truck and will try to put them on his 77 in the next few weeks. If it all works out he will get about half a foot of lift from it. When we do it I will let you know how it worked out.
Old May 22, 2006 | 08:04 PM
SwampBilly's Avatar
SwampBilly
sounds good jmudder but.....wut parts truck was it from?
Old May 24, 2006 | 05:50 PM
Jmudder79's Avatar
Jmudder79
It was from an 80's Chebby. I will find out the exact year.
Old May 24, 2006 | 07:52 PM
ivanribic's Avatar
ivanribic
Depends on if the F250 is an early or late model. The early 77 F250 4x4 ("Hi-boy") has narrower rear springs but if it's a late model (77.5) then the rear springs will be 3" and will fit fine. If you're not sure just measure your rear spring width. My rear springs are for a 78/79 Bronco.
Old May 24, 2006 | 09:21 PM
SwampBilly's Avatar
SwampBilly
i guess they wont work then ive got a highboy
Old Aug 25, 2006 | 12:36 PM
gittinwidit's Avatar
gittinwidit
Early Bronco leaves are 2.25 inches wide, exact width as Hi Boy but shorter distance between spring hangers.
Old Aug 26, 2006 | 05:58 AM
Jmudder79's Avatar
Jmudder79
Glad someone bumped this thread. We actually finished the Chevy spring hangar swap last weekend. We ended up using 2 sets of front hangars because they drop like 5-6 inches below the frame, the rear hangars aren't much different then the stock Ford ones, and a shackle flip in the rear. It gave him roughly 8-10". Not exactly sure, didn't break out the tape measure yet. The Chevy hangars also sit farther out from the frame rails then the Ford ones so the springs won't line up right. But we have a grinder and a welder, so we just moved the perches over and it worked perfectly.
Old Aug 27, 2006 | 08:55 PM
SwampBilly's Avatar
SwampBilly
nice good job u finally did it...lol....well i got six inches doin what ivan did to his truck just droppin brackets and stuff its doin all right i took it out to holy lands and i didnt get stuck once it was nice for once having this ford muscle with low as hell gears pull through.....i like this truck we went out for 5 hours....besides ever since i painted it john deere all the girls think my tractor's sexy hehe
Old Aug 30, 2006 | 12:22 PM
cowboyty's Avatar
cowboyty
Have anyone tried swaping front leaf springs on a 78 F250 with super duty front springs? I had a set of 2004 f250 front springs givin to me and I am going to try to put them under my f250 to replace the worn out front springs. Hopefully I can get to it next week if it all works out.
Old Sep 1, 2006 | 06:36 AM
Jmudder79's Avatar
Jmudder79
Thats what we did on the front of the truck I was talking about earlier. We put in 10" front leaves for a SD
Joel Cassell
Jan 12, 2018 10:55 AM
saleen5.8
Dec 1, 2013 11:00 PM
Monster356
Jun 29, 2011 06:41 PM
78pace
Apr 3, 2011 12:50 PM
ibleedblue1385
Offroad & 4x4
Feb 23, 2011 04:41 PM
