keyed ignition switch relacement
Old May 22, 2006 | 01:03 PM
79brncnwht's Avatar
79brncnwht
I lost the keys to my bronco this weekend. I want to put in a new ignition switch in my 79 bronco. not worried about the door locks.
How do I do this? is it difcult? any thing special to watch out for? any help or advice would be really helpful.
Old May 22, 2006 | 06:00 PM
Franklin2's Avatar
Franklin2
For the ones on the column you take a chisel or large screwdriver and bust it out. The local parts stores carry new ones with new keys.
I do not know what you would do with a dash mounted switch.
Here's the instructions for the later models on the column.
http://www.autozone.com/servlet/UiBr...3d800a9e94.jsp
Old May 23, 2006 | 01:52 PM
lsrx101's Avatar
lsrx101
It's a little difficult without the key. DONT try and chisel out the old lock cylinder, the impact will damage other parts of the column.
Break off the "wings" from the old cylinder where the key goes in. Get a large flat blade screwdriver with wrench flats up near the havdle. Tap the screwdriver firmly into the keyway. Push in on the screwdriver as hard as you can while turning it with a wrench to the RUN poition. Push the pin and remove the cylinder. This will shear the lock cylinder internally without damaging the column.
There used to be a tool available for this very thing called a Ford Bypass Key. It fell into the same legal category as lock picks and lockout tools. The last time I looked for one, I couldn't find one.
Old May 24, 2006 | 10:16 AM
79brncnwht's Avatar
79brncnwht
Thanks for the advice lsrx. last night I couldnt figure how to get it out without breaking it. But I dont have a key for it so doesnt matter if it breaks. I didnt think about that. So I took out the switch and every thing. While trying to get this apart I broke the plug housing and the springs on the back of the switch. I will check my parts truck for a working switch tonight.
Old May 25, 2006 | 09:30 AM
lsrx101's Avatar
lsrx101
Duh, I had a brain fart. 79 used a dash mounted siwtch, right? I was talking about a column mounted lock cylinder.
Old May 25, 2006 | 10:05 AM
79brncnwht's Avatar
79brncnwht
got the Switch assembly out of the dash on the parts truck and onto the bronco last night quick and easy. fired right up. I have a big smile.
RBerry9511
Feb 7, 2020 04:31 PM
Mellis4693
Jun 27, 2016 07:28 PM
bigcrunch
Large Truck
May 8, 2016 11:52 AM
Shanghai
1978 - 1996 Big Bronco
Dec 23, 2015 01:39 AM
Jon.G
Electrical Systems/Wiring
Feb 11, 2015 02:32 PM
