Strangeness....
Old Mar 27, 2002 | 10:53 PM
sparky's Avatar
sparky
Strangeness....
Old Mar 31, 2002 | 02:52 PM
cybercoyote's Avatar
cybercoyote
Strangeness....
Ok, here we go again.
My 67 f-100 has a diffrent rear end installed by the truck's previous owner. It's a ford 9", but the strange part is, that as far as I can tell, it has somthing like a 1:85 gear ratio. I found this out by jacking up the truck and rotating the axle while counting rotations to one tire rotation. Did I do this right?
If that wasnt enough, the transmission is geared low enough, that even with this rear end, the truck tops out at about 60-70 mph in 4th gear. (manual 4 speed). My quesion is: Is it possible to rebuild the tranny, at least the 4th gear, to increase the top speed of the truck, or would it be easier and cheaper to simply get another tranny? If that's the case, can anyone suggest any? Cruising around in 4th gear at 30 mph just doesnt seem right.
The only thing that's impossible is that no other possiblties exist.
Old Mar 31, 2002 | 03:22 PM
Mil1ion's Avatar
Mil1ion
Strangeness....
Yea ,you did it backwards.
Turn the Tire One revolution and count the turns of the driveshaft instead.
Dennis
[font color =red]Calgary,Alberta,Canada [/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color =green]http://www.clubfte.com/users/mil1ion/index.html[/font]
[font color =green]http://community.webshots.com/user/mil1ion[/font]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Mar 31, 2002 | 07:01 PM
cybercoyote
Strangeness....
<Yea ,you did it backwards.
Turn the Tire One revolution and count the turns of the driveshaft instead.>
Allright...tried it that way, and got the same answer...
Old Mar 31, 2002 | 09:18 PM
jowilker's Avatar
jowilker
Strangeness....
Corwin, A couple of things there are no 9" 1:85 ratios that I am aware of, and your tranny ratio is 1 to 1 in high gear, just like all none overdrive trannys, regardless what is in front of high gear. If your truck is hitting the wall at 70, I would guess you have something like a 4.11 in it. My truck has used all of the numbers on the speedo (100) at 3600 rpms. It has a 2.75 gear in it.
Try rolling the truck on a lever area with a friend pushing the truck and watching the tire while you count the drive shaft revolutions. You can tape a piece of string to the ds and count the winds with one roll of the tire also.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Mar 31, 2002 | 11:46 PM
cybercoyote
Strangeness....
Thanks..I'll try that tomorrow.
I figured there wasnt any such gear ratio, that's actaully why I posted the question. It didnt seem right...
Old Apr 1, 2002 | 05:04 AM
jowilker's Avatar
jowilker
Strangeness....
Letr us know what you come up with.
John
jowilker email me
Old Apr 1, 2002 | 08:28 AM
blatherskite's Avatar
blatherskite
Strangeness....
If the rear-end is 'open' (non posi or non trac lok etc) I think you have to multiply your revs by 2 to get the real gear ratio when you do it on jack stands. So you probably really have a 3.70. Your count should reflect this if you do the rolling it on the level ground method as mentioned.
Old Apr 1, 2002 | 07:41 PM
red68ranger's Avatar
red68ranger
Strangeness....
That is a fact.
Plus with an open, if you're on a hill, don't try to jack up one rear wheel unless you apply the e-brakes. Soon as it gets off the ground, the other one will roll.
Dan Blackwell
'68 Ranger, 360, Pop bought it for $2605 brand new
I put in the c6, ps & pdb; original took too many hands 'n feet to drive, shift, signal, brake and dim.
