Oil Change
Old May 19, 2006 | 10:27 PM
conger's Avatar
conger
Oil Change
Only had my 04 F350 powerstroke for about 2 months now. So far no real problems, but I'm keeping a close eye on the coolant level. My question is, how often do you do oil changes? The owner's manual says 12500 km. The dealer's maintenance sticker shows 5000 km. What's the average. I use to do most of my own work on my old F150, So I'm also trying to find some info on the F350s & powerstroke diesels. Haynes doesn't make a book as new as 04, so are there any alternatives other than shelling out hundreds of dollars for the service set of books.
Old May 19, 2006 | 10:49 PM
bf250's Avatar
bf250
change every 5k miles for normal use and 3k miles for severe use.
so...thats 5k times 1.6 equals 8k kms
the book answer, don't know
Old May 20, 2006 | 07:38 AM
Spokaloo Jim's Avatar
Spokaloo Jim
I saw a CD on E-Bay with all the information for the 04 model year F250-350 to include engine, body, electrical for a buy it now price of $30 plus shipping. Might be an option.
Old May 20, 2006 | 07:57 AM
vloney's Avatar
vloney
do you have any buddies that are ford techs? they have access to all manuals and wiring diagrams from their home computer
Old May 20, 2006 | 09:14 AM
X GM GUY's Avatar
X GM GUY
I change my oil every 10,000 Km, (6,000 miles). Oil changes on the 6.0L easy. Just chech in the FTE 6.0L tech manual
Old May 20, 2006 | 10:12 AM
wb6anp's Avatar
wb6anp
I always buy the factory service manuals from Helms, yes expensive but if you plan on keeping the truck well worth the cost.
Old May 20, 2006 | 03:01 PM
dschuffert's Avatar
dschuffert
I change mine every 7,500 miles. I also take an oil sample at each change. So far no problems with 25K miles on it.
Old May 20, 2006 | 05:22 PM
conger's Avatar
conger
Thanks for the advice guys. I was thinking 10k would be about right. Where would I find an FTE manual. I've be steering away from Ebay, been burned a couple of times now. I might go for the shop manuals if I can find a deal. I was thinking maybe someone had a book, like Haynes. I'm not looking to be able to tear the engine down and rebuild; but something that will give me some specs and service outlines on the F350. Brakes, fluid changes, front end servicing, general troubleshooting, etc. That sort of thing.
Old May 21, 2006 | 08:35 AM
deacjrt's Avatar
deacjrt
I also change mine at 5K, I also rotate the tires and drain the HFCM at his internval. Been using this method since new, got 50,000 miles out of the stock BFG tires. Just purchased new BFGs 295/75/16 and hope to get 50K out of these also sticking to the same maintenance schedule and should have no problem doing so since it is the same tire, just larger. As for the oil change, 5K seems fine, I think I could go longer if I absoutley had to. Also doing an oil change every 5K means every 3rd oil change your fuel filters will get changed also, so it is easy to do it at the same time. And, as an added bonus you will smell like Rotella and Diesel, an excellent cologne that not even Ralph Lauren could dream up. Drives the ladies WILD!!!!!!!!!!!!!
Old May 21, 2006 | 03:21 PM
vloney's Avatar
vloney
deacjrt--something must be wrong, my wife doesnt say anything like that(its more like making comments about my ancestry or species)
Old May 21, 2006 | 04:07 PM
deacjrt's Avatar
deacjrt
Very true, I read my wife my comment and she kindly called me a "Freak." I'll just keep living in a dreamworld.
Old May 21, 2006 | 05:55 PM
conger's Avatar
conger
My wife's ok with the grease and oil. But she doesn't like the occasional spider that finds its way into the house from the garage.
Old May 21, 2006 | 08:31 PM
dschuffert's Avatar
dschuffert
I mentioned your post to my wife. She thinks we are all nuts! She still doesn't understand, nor probably ever will, why I get a smile every time that diesel engine fires up! She is also tired of me telling her about the 60 ton M60 diesel engine tank I used to ride in too!! Nothing like the smell of diesel in the morning.......
Old May 22, 2006 | 10:17 AM
X GM GUY's Avatar
X GM GUY
Conger: The Tech folder is the second thread on the 6.0L page. Lots of good info.
Old May 22, 2006 | 10:19 PM
conger's Avatar
conger
Thanks, I new to the site and still finding my way around.
jdq1986
Dec 1, 2014 12:43 PM
BrassMonkey
2009 - 2014 F150
Jan 16, 2014 06:43 PM
rolande
1997 - 2003 F150
Dec 2, 2008 11:33 PM
scooter_1968
May 8, 2003 03:36 PM
