speedo set up help
Old May 19, 2006 | 12:00 AM
Nigel's Avatar
Nigel
speedo set up help
Well it is time to make the speedo work in my offroad rig again and I am kind of starting from scratch.
Background info: 78 f250 reg cab 400/np435/203/205 5.13 gears 42" tires
First of all what is the application for which the longest cable is made? With the doubler I need a longer speedo cable. plus the stock one is TOAST.
How do i figure out the gear I need to be close to accurate. i am not sure what the original speedo gear was.
how many revolutions per mile do these speedos make?
Thanks
Ted
Old May 19, 2006 | 12:09 AM
Mil1ion's Avatar
Mil1ion
http://www.tciauto.com/tech_info/speedo_gears.htm
http://www.transmissioncenter.net/sp...___va.htm#ford
From the rockauto site.
ATP Part # Y848
M.T.; 4WD, w/4 spd., from serial no. 500 001 {Speedometer Cable / OE# D5UZ17260C}
Old May 19, 2006 | 12:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First: FAQ thread at the top of the 73-9 forum for speedometer calibration info.
Old May 19, 2006 | 10:15 AM
ivanribic's Avatar
ivanribic
They squish the boys so I prefer just regular swim trunks.
Oh, you meant THAT kind of speedo . . . nevermind. Carry on then.
Old May 19, 2006 | 10:40 AM
Nigel's Avatar
Nigel
Thank Ivan you are a life saver
Dennis the calculator you posted is perfect. All the others I have found involved the tooth count on the original gear and i suspect it has been changed by a previous owner.
Any suggestions on the cable issue? Is a drive tain with a c-6 longer than a 435? I think i need a little longer cable to make up for the doubler. The stock cable had been rubbing on the exhaust and is not use for measuring at all. The longest I have found is 95" but I don;t know how long the original was.
Thanks
Ted
Old May 19, 2006 | 12:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Speedometer shops in the larger cities can make a cable of any length with the proper ends on it.
fordman1090
Apr 2, 2010 07:30 AM
trugertha
Apr 16, 2009 10:46 PM
ken selvy
May 13, 2008 01:12 AM
64fordf100292
Sep 16, 2007 07:20 AM
turbosek2
Jul 20, 2003 05:56 PM
