highboy/lowboy compatability
Old May 17, 2006 | 02:57 PM
daddyo4's Avatar
daddyo4
I have a f-250 highboy (1975) frame with no front axle or springs, and a lowboy (1979) donor truck. from what i can tell, the '79 springs will work on the '75 frame. can anyone confirm this?
Old May 17, 2006 | 04:01 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Both use 3" wide springs on he front. I belive they are the same length.
Old May 18, 2006 | 07:35 PM
daddyo4's Avatar
daddyo4
Looks that way to me, just thought I'd ask. Thanks for your input!
Old May 19, 2006 | 07:05 AM
Jmudder79's Avatar
Jmudder79
Chech the frame width between the two trucks. The highboy may be a bit narrower. Not to say it can't be done, but it may require some spring perch relocating. I know from experience(swapping a post 77.5 bed onto a pre77.5 highboy) the rear frame is different. Not 100 percent sure on the front.
Old May 19, 2006 | 08:49 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
the rears are different widths, front spring perch width is the same
if you use some of the flat springs from the front of a "lowboy" the truck will sit about 2" lower than it did with it's stock springs
Old May 19, 2006 | 03:39 PM
leadmic's Avatar
leadmic
The highboy and lowboys are the same width in the front. The leif springs are the same width and length and front axles and leif springs are interchangeable the only problem you might run into is the front drive shaft. All highboys use a low pinion front end and devorced t-cases and all lowboys use a high pinion front with married t-cases so if you put a lowboy front end into a highboy without a lift you might have front drive shaft to trans cross member problems.
The rear end is a diffrent story highboys use a 2 1/2 wide leif and low boys use a 3 in leif also they are diffrent leignths. The highboy frame is also narrower in width at the back axle by about 4 to 6 inches.
Leadmic
