Pre-pump mod
Old May 18, 2006 | 07:45 PM
fd1109's Avatar
fd1109
Pre-pump mod
Hey fte'rs , I spend most of my time on the 01 site but have a question ? I'm working on a 96 psd and noticed that it has the quik-connect fittings on the fuel pump that is on the frame rail, is there also a problem with this year model with air being pulled in and getting into the fuel lines and is the pre-pump tank mod necessary ? Thanks
Old May 18, 2006 | 10:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Do you have a picture of it? Ford did not put an electric in-line pump n the PSD until 99. The 96 has a mechanical pump mounted in the engine valley below the turbo.
Old May 19, 2006 | 06:29 AM
tjbeggs's Avatar
tjbeggs
i think the difference is that the pump on the obs is low pressure lift pump then it has a second stage to pressurize the fuel. the superduties has a high pressure lift the whole way. so by drawing the fuel at low pressures the air does get sucked in.
90pioneer
Nov 3, 2013 08:23 PM
Hotwheelbill
36
Mar 21, 2008 02:25 AM
05f250fx4
Oct 15, 2006 07:18 PM
jrciii56
22
Sep 19, 2006 02:07 PM
hink10
30
Feb 23, 2006 12:47 AM
