Rag joint replacement
Old May 18, 2006 | 05:38 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Im working on my 79 F150 4x4 project and finally got around to replacing the rag joint. I removed the 2 bolts that holds the steering shaft to the gear box but I cannot get the studs out the holds the rag joint to the gear box. Any one else have this problem? Any suggestions?
Old May 18, 2006 | 05:42 PM
cujo8's Avatar
cujo8
You need to cut off the studs to remove them. The replacement rag joint kit will have bolts to replace those studs.
Old May 18, 2006 | 05:45 PM
STGFordCrazy04
that explains an aweful lot. Thank you.
Old Oct 22, 2006 | 02:04 PM
Para045's Avatar
Para045
New Rag Joint
After reading a bit about this problem with loose steering on my 79 F100 2WD I am starting to think that this rag joint is the main culprit as my previous 78 4WD had slop in the steering but nowhere near as much even though there were more joints in the steering to wear and one of the unijoints was shot. So where do you get a replacement rag joint - are they a genuine part or are they made by an aftermarket company
Old Oct 22, 2006 | 02:37 PM
dkstuck's Avatar
dkstuck
Parts store, if not behind the counter, hit the HELP section.
Old Oct 22, 2006 | 02:46 PM
STGFordCrazy04
I bought mine at napa for like $10. Its napa part number 630-1012 and it was on one of the turning racks that sell all types of common replacement items. Hope that helps
Old Oct 22, 2006 | 03:16 PM
Alvin in AZ's Avatar
Alvin in AZ
I suggest you get the stiffest and hardest "hunk of conveyor belt" looking one you can find. :) BTDT
The first few I ran across (way back when) were crap.
Sorry, don't know where to point you to where to get a "good" one anymore. :/
Alvin in AZ
Old May 28, 2012 | 04:59 PM
MUFUNGO JONES's Avatar
MUFUNGO JONES
1977 Ford F350 Rag Joint replacement
I need instructions on how to replace the rag joint on a 1977 F350. Please be specific on all steps of replacement. Some one has suggested that part of the steering column must be loosened but that all they said. Please help. Thank you, Mike
Old May 28, 2012 | 05:02 PM
MUFUNGO JONES
1977 Ford F350 Super Cab Camper Special 460 CID, C6 70,000 original miles and one owner
I need instructions on how to replace the rag joint on a 1977 F350. Please be specific on all steps of replacement. Some one has suggested that part of the steering column must be loosened but that all they said. Please help. Thank you, Mike <!-- / message -->
badasssapper67
Feb 21, 2017 09:44 PM
greasy rider
16
Mar 14, 2016 01:00 PM
tl1965
Nov 26, 2015 07:15 PM
DougieWebb
Apr 9, 2013 06:27 AM
tomlauten
Mar 13, 2013 10:28 AM
