Rag Joint Replacement?
Old Apr 7, 2013 | 03:18 PM
DougieWebb's Avatar
DougieWebb
Anyone have experience replacing this? Difficult?
My steering is L O O S E and I noticed that the fibrous part of the rag joint is eaten up pretty bad.
Old Apr 7, 2013 | 03:22 PM
bamaf150's Avatar
bamaf150
Its easy, 2 bolts. They sell a generic rubber disc for Fords in the Help section of the auto parts chainstores, I got one for like $7
Old Apr 7, 2013 | 04:07 PM
DougieWebb's Avatar
DougieWebb
Awesome, thanks Bama
Old Apr 8, 2013 | 12:43 PM
DougieWebb's Avatar
DougieWebb
But once I unbolt this thing, how do I get the shaft out of the way to put the new rubber disk on?
Old Apr 8, 2013 | 02:16 PM
bamaf150's Avatar
bamaf150
The rubber disc should just slip between the two flanges of the coupling once the bolts are out. there is a pinch bolt that holds the flange connected to the ps box splined shaft that might have to be loosened to give you some wiggle room but I dont think it should be necessary.
2wd is a bit different than a 4wd I see, its been quite awhile since I looked under the hood of a 2wd dent.
Old Apr 9, 2013 | 06:27 AM
DougieWebb's Avatar
DougieWebb
You were right on target Bama. Thanks so much! Only took me about an hour and a half (good for me - I am a pretty clumsy mechanic).
The disk just slid out, did not have to touch the pinch bolt.
And steering is MUCH improved. Good investment of $10.
ddepumpo
Apr 9, 2018 03:25 PM
FTWDEVIANT1
Offroad & 4x4
Feb 10, 2008 10:32 AM
timarkr
Mar 24, 2005 08:55 AM
TdiRAcing
Jan 28, 2005 08:17 AM
pollock
Aug 28, 2004 04:00 AM
