rag joint rubbing
Old Mar 13, 2013 | 07:38 AM
tomlauten's Avatar
tomlauten
rag joint rubbing
I have a 73 f100 4x4 with manual steering and i just replaced the steering gear and the rag joint rubs on the frame. It looks like it was doing this with the old gear also. I just bought this truck. Also someone has welded about half way up the shaft. Are there different size rag joints on these trucks between 2 and 4x4
or power non power. Any info would be helpful.
Old Mar 13, 2013 | 09:01 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Are you sure it's a rag joint? My Ford parts catalog doesn't show a rag joint on the 4WD it shows a coupling with a cross shaft and bearings.
Here's the illustration. This is for a 4 spd manual column, automatics show the same set-up.
File Type: pdf
Old Mar 13, 2013 | 09:05 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You know, rereading your statement it sounds like someone may have jerry-rigged the steering to get around replacing the lower shaft. They may have pieced in a column shaft from a 2WD to do this .
Old Mar 13, 2013 | 09:48 AM
jim collins's Avatar
jim collins
Not knowing how well that weld is , i would get it off of my truck and fix it right.
Old Mar 13, 2013 | 10:04 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Agreed!
Old Mar 13, 2013 | 10:28 AM
tomlauten's Avatar
tomlauten
I also agree after looking at the pic some one has cobbled it up and i will be salvage hunting this weekend. thank you for the quick responses.
tom
mofoco1
Dec 1, 2015 12:00 PM
GJBain
Oct 8, 2013 04:33 PM
Frankie33
Feb 6, 2013 01:58 AM
MavSprint
Jan 31, 2013 08:08 PM
otto
Aug 12, 2001 06:28 PM
