Modular V10 (6.8l)
Stutter and missing V-10
Old May 20, 2006 | 10:01 PM
ibyourhucklebery's Avatar
ibyourhucklebery
Ahh yes..the rubber hose trick!
Old May 20, 2006 | 11:30 PM
bendrbat's Avatar
bendrbat
Pardon my ignorance but what are COP'S and IAC's? My V10 is somewhat of a dog and I need to know what these are since everyone talks about them all the time.
Old May 21, 2006 | 12:12 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
COP = Coil-on-plug - each spark plug has it's own coil, sitting right on top of it.
IAC = Idle Air Control - it's a servo that the computer spins one way or the other to increase or decrease air getting past the throttle body. This controls the idle. It does the same thing as the idle speed screw on carburators.
Old May 21, 2006 | 03:17 AM
Spamy's Avatar
Spamy
Naw, I used the hose to blow the air way in the holes and get all the sand out. That stinkin sand makes its way into everything. Thats probably why my front bearings sound like a pocket full of marbles driving down the road.
Just the extension and socket minus the wrench worked good for me. It was pretty easy to tell if it was threading right. After a few stripped vital parts you learn a feel for this pretty fast, or you never pick up a wrench again. Actually, I do know a few guys that still cross thread 50% of everything they put together. Ill never buy anything used from them!
Honestly, this site probably saved me at least a weeks time or a bunch of money because of the help. Thanks a bunch.
Old May 21, 2006 | 11:16 AM
bendrbat's Avatar
bendrbat
Unhappy
Okay, when people talk about checking these items, what am I checking for, and what is the correct procedure for checking them?
Maybe I am just expecting to much out of this truck, the combined weight of my truck and trailer is right at 18,650 lbs and I can't maintain 55 up hills. All you guys talk about these trucks like they will pull anything how ever fast you want to go just step down on the throttle. I don't have any problem with mashing my foot to the floor and letting her wind up but on a good grade, she won't wind. Any thoughts? I have changed the air and fuel filters and that made no difference. The engine purrs like a kitten and never skips a beat so I am at a loss to understand what is up.
Old May 21, 2006 | 11:53 AM
krewat's Avatar
krewat
bendrbat, what gears do you have? If they are 3.73's, they will hurt the towing performance a lot!
Old May 21, 2006 | 11:56 AM
bendrbat's Avatar
bendrbat
Krewat, I have 4.30's and from reading in here they are the more desirable gears to have for towing.
Old May 21, 2006 | 01:35 PM
krewat's Avatar
krewat
Just checking - sounds like something is definitely a-miss (no pun intended).
Reset the computer, there's a chance it retarded the timing from some bad gas and never adjusted back.
Old May 21, 2006 | 01:43 PM
bendrbat's Avatar
bendrbat
Resetting the computer is accomplished by disconnecting the battery for a few minutes and then reconnecting?
Old May 21, 2006 | 01:56 PM
krewat's Avatar
krewat
Yes. Disconnect the battery, put the headlights on and leave it for an hour.
That'll do it.
rhamm150
Modular V10 (6.8l)
20
Sep 16, 2016 08:04 AM
scoutcamper
6.7L Power Stroke Diesel
Jan 7, 2016 10:48 AM
2005 Ex Limited
Mar 22, 2015 08:21 PM
peachboy
34
May 14, 2011 06:38 AM
jwhracer
1983 - 2012 Ranger & B-Series
16
Dec 8, 2006 01:47 PM
